What torque for manifold bolts/nuts - fsm conflics PICS inside!!
Old Aug 25, 2009 | 09:49 PM
boostedwrx's Avatar
Lightbulb What torque for manifold bolts/nuts - fsm conflics PICS inside!!
I'm slowly piecing together my BBK and tonight while looking at the FSM and torquing my manifold to turbo I noticed the book has two
different torque ratings for the 2 nuts and the 2 front studs. See pics. My question is what is everyone else torquing theres to? I don't want no leaks~!!
The first pic (most commonly showed one on EvoM) shows them to be torqued at 38 +/- 3 Check for circle
This second pic (from the engine overhaul section of the FSM) it shows them to be torqued at 47 +/- 3 which is a good 9 ft/lbs higher than the other page. Check for circle
Am I blind or what? It's taken from the Evo 9 cd so it should be good. I currently have them set to 40 ft/lbs but wanted to hear from others. Any help would be much appreciated!
Old Aug 25, 2009 | 09:57 PM
Sievers's Avatar
Well the second is clearly for a IX. I do not know if anything was changed between the VIII and IX but that could be the difference but I have no idea. I went off the torque specs from the first.
What you have should be fine. I see no problem with that.
Old Aug 26, 2009 | 05:11 AM
MR Turco's Avatar
it doesn't matter, i always add 5ftlbs to the number in the FSM when it comes to non-internals.
Old Aug 26, 2009 | 06:44 AM
boostedwrx's Avatar
Thanks - I may bump it up a little bit to 45 or so. It's just weird how there is a ~10lb variance between the two pages and/or models. So far I haven't found any other torque rating out of the ordinary..
Old Aug 26, 2009 | 07:45 AM
Sievers's Avatar
Yeah. let me know if you figure out anything more bro
Old Aug 26, 2009 | 10:42 AM
MasterNater's Avatar
Well, in both pictures they used the same Newton Meter value of 64 +/- 5Nm. That's roughly 47 ft-lbs.
