EVO 7-8 turbo on DSM motor
Old Oct 14, 2003 | 06:58 PM
Bimmubishi's Avatar
Maybe someone thought it was OT and moved it. Anyway, Adam from Z1, you say it doesn't fit, Tye from RRE says it does. I have a feeling the DSM manifold and the EVO 8 are the same bolt pattern to the head.
With that said, does anyone have firsthand knowledge of fit? Can someone compare gaskets or something?
Thanks again, sorry to repost. I can't see why this would be deleted it's an interesting query (at least to me)
Alex
Old Oct 14, 2003 | 07:35 PM
94AWDcoupe's Avatar
The manifold bolts right up. The inlet to the turbo ends up smack against the alternator. So to make it work you have to loose the a/c and move the alternator to the other side. You will also have to fab custom 02. The evo one will hit the block or motor mount. i think you have to use a manifold spacer also.
If you are paying a fair amount for the EVO turbo. I would say it is not worth it.
Old Oct 15, 2003 | 03:37 AM
Bimmubishi's Avatar
Great info!! Thanks a lot man.
AL
