Few questions about 30k checkup
2006 Evo IX
So I'm at 25,753 miles right now, and am about to have my oil changed.
Should I go ahead and change out all my other fluids now or what? To prove that I just didn't blatantly post this thread up without searching...I have been reading this.
https://www.evolutionm.net/forums/ev...uantities.html
I'm just real bad when it comes to buying fluids online and was wondering if someone could basically check and make sure I'm buying the right parts....
Transmission Oil:
-Amsoil MTG, capacity 2.9 qts
Transfer Case:
-Diaqueed LSD Fluid, capacity 0.63 qts
ACD Operation Fluid (I just have to check this..not replace....right?)
Rear Dif:
Diaqueen LSD Fluid, capacity 0.58 qts
**So the rear dif. and t-case use the same fluid?
Transmission Oil:
Transfer Case:
Rear Dif:
