will evo 8 turbo fit on 2nd generation eclipse?
Old Sep 5, 2009 | 08:29 PM
evo4life400's Avatar
hey guys sorry if this is in the wrong section but i had someone ask me this question on ebay and i had no idea because i have no knowledge of eclipses. if anyone knows please help me out! thanks
Old Sep 5, 2009 | 08:42 PM
Piro Fyre's Avatar
Q: Can I bolt on an Evo 8 turbo to my dsm?
A: No, the evo uses a TD05HR-16G6-9.8T (03’-04’ models), TD05HR-16G6-10.5T (05’ models) or a TD05HRA-16G6-10.5T (Ti Alloy option).
All Evo 4-8 Turbos are twin scroll designs meaning that the engines exhaust is divided into two channels. As the engine exhausts in pulses. It is supposed to result in quicker spooling. From the Evo 4 onwards, the Turbo spins in the opposite direction, i.e. Anticlockwise (hence the R in the turbo name). The Titanium Alumnide alloy used (factory option) has less inertia and thus spins up around 500 rpm sooner. These Titanium turbos can be indentified by the A in their name.
There are people who have installed evo 8 turbos on dsms, it is not impossible, just not very logical. You will need the evo 8 manifold and hardware. And you will have to relocate the alternator and make a bunch of custom piping. You will be a lot better off buying a turbo that is made for “your†car. There are numerous options out there that will cost less than the evo 8 setup, but will make much more power.
The Evo 3 16g that everyone is use to is a TD05H–16G6-7. This turbo will bolt directly onto 1gs and will fit 2gs with that have been modified to use a 1g turbo.
http://mitsubishiforum.com/forum/arc...p/t-17536.html
Old Sep 5, 2009 | 08:48 PM
ok thanks for the help! i appreciate it
Old Sep 6, 2009 | 06:14 AM
Steve93Talon's Avatar
Short answer - no.
Long answer - yes, it's been done, requires a custom manifold, o2 housing, lines, and other things. Far from worth it when you can just get an EVOIII 16G for $499 that's a direct bolt-on to a DSM and makes just as much power.
Ice raptor
Jan 22, 2017 05:51 PM
Eclipse07
Oct 20, 2013 10:28 AM
vexor
Oct 22, 2012 04:34 AM
metalmellinium
Jun 7, 2011 10:57 AM
apexisilver8gsr
10
Oct 23, 2010 04:32 PM
