new Fuel pump, injectors, installed: Starting issues?
Old Sep 8, 2009 | 10:38 AM
shuttlegoose's Avatar
I recently installed a new turbo along with fic 850 injectors, and 255 fuel pump. Im assuming everything was installed correctly as the car started fine and was tuned on the dyno with no issues. I noticed now im having some starting and cranking issues. Sometimes the car will not even start when i attempt to start, but then usually does the second time i try to crank it over. Its not every time, but i would say 8 times of of 10 im having this problem. Is this normal with bigger fuel pumps and injectors???
Old Sep 8, 2009 | 05:00 PM
bumpity bump. would reaaaally like to resolve this issue.
Old Sep 8, 2009 | 05:06 PM
tscompusa2's Avatar
No its not normal. whats your injectors scaling set to on the tune?
Old Sep 8, 2009 | 06:52 PM
oooo thats a good question. 770 i believe and then the latencies were pulled from a set of rc880s i believe that someone used but im not sure.
Old Sep 10, 2009 | 05:46 PM
tscompusa2's Avatar
make sure the fuel trims are all close to 0
