Airflow for Evo IX Turbo, FP Green & BBK
Old Sep 12, 2009 | 05:32 AM
racer135's Avatar
What is a typcal airflow for the smaller stock frame turbos like the IX, Green or BBKs? Do you have an airflow plot to share? Right now I am flowing 2000 Hz by 7000 and toping to about 2050 by 7500. Is this typical, low or high? I know it is not high but I am not sure if it is low.
Here is a plot of my current airflow. Is this typical? Good or Bad?
Old Sep 12, 2009 | 06:47 AM
cij911's Avatar
I recall seeing several posts by Bryan from GST that showed airflow. You may want to search in the Ecuflash section as I believe he was discussing tuning as it related to airflow.
Old Sep 12, 2009 | 08:08 AM
racer135's Avatar
Thanks for the hint! I forgot about that. It looks my turbo is flowing about the same as an FPGreen. The plot below was posted by Bryan some time ago. Very similar to waht I got. But I started the log a little later but at full boost it is about the same.
Old Sep 12, 2009 | 08:57 AM
cij911's Avatar
^^ Not sure how an evo8 could flow as much as a green .....
Old Sep 12, 2009 | 01:36 PM
racer135's Avatar
It is an Evo 8 but with a 20 G and Kelford 272 cams.
Old Sep 12, 2009 | 01:50 PM
scheides's Avatar
EvoM Moderator
Here's some early airflow/boost numbers from my BBK:
Old Sep 12, 2009 | 04:04 PM
racer135's Avatar
That is some nice airflow from the BBK. That is a BBK Full right? With my setup I think I can't hold 25 psi to redline. By design I am at 22 psi by redline but I doubt I can hold 25. I am now at 92% WGDC and only hitting 22~23 psi by redline. That is with the stock airbox.
Old Sep 12, 2009 | 07:25 PM
scheides's Avatar
EvoM Moderator
Yup, BBK Full. Holds boost awesome on the OEM WGA! These are on just pump gas. Dyno numbers are in the dyno section, just search for BBK and my username
3VOLUTIONIST
Dec 20, 2024 03:55 PM
LIGHTSPD
22
Sep 1, 2009 07:09 AM
TakaseEVOIXSE
36
Jul 27, 2009 06:49 AM
Evil_1
Jun 15, 2008 06:47 AM
ns4g63
Oct 28, 2007 11:51 PM
