crank replacement
crank replacement
The thrust bearing was worn and when i go to replace it i realise that where the bearing would hold the crank in place was abit worn also. Will the crank from an e7 or any other model fit my e4?
It should since that was the first model they rotated the engine to the layout the current Evo's have. I'd get a second opinion though as i don't know if the crank itself is the same. Good luck.
Aaron
Aaron
