06 mr finally where i want to be 430!
To get 1000RPM sooner spool and still make mid 400s the HTA green would do the job with meth "with the right supporting mods of course". Some Kelford 272 cams would add some more top end but lose just a little spool and you would need aftermarket valve springs... It becomes a balancing act as to what you want out of your car honestly. The GSC S1 cams are a good choice if you want more power across the rev range and dont want to change valve springs and lose VERY little to NO spool which the OP didnt want to do all that.. That is why i suggested he get the GSC S1s and they fit the bill and did there job perfectly! They didnt lose any spool and the car actually feels more powerful everywhere after the cams!
Also take into account this is on straight 93 octane pump.. no meth... So with methanol or E85 i could have this setup coming in sooner
Also starting the pull sooner will net peak TQ at a lower RPM as boost will come on sooner.
Depending on your overall power goal will determine what turbo you need to go with.
it is like a whole new ride its a blast, minus the fact that you have to shift sooner and i keep forgetting to do so, and I end up hitting rev limiter ha ha ha ha ha
ya my car is not tracked its my little baby that sits in the garage, and is driven on occasion I just shipped off my other 03 8 to AMS for a full drag car build ! eat your hearts out suckers ! ha ha
Colt4g63
Nov 26, 2013 04:26 AM
mantosride
Dec 27, 2009 10:48 AM
