03 Evolution 8 Motor Question..
Old Sep 27, 2009 | 11:06 PM
crewdawg130's Avatar
while you down there ARP main studs
Old Sep 27, 2009 | 11:24 PM
B00STiNKRiSTYNA's Avatar
^^ thanks lol.. NOT
Old Sep 27, 2009 | 11:35 PM
xspsi4's Avatar
No never put ARP mains or rod bolts in with out honeing/boring of the hole as the ARP will distort the holes and your bearings will spin, It looks like you have enough problems
Good luck getting her back on the road.
Old Sep 27, 2009 | 11:41 PM
UUHHHMMMM. i ment while shes building her engine..... Look at her other post.
Old Sep 27, 2009 | 11:48 PM
xspsi4's Avatar
Oh, I could not tell from the pics what exactly was damaged other than the head and it looks like a flywheel bolt backed out.
Old Sep 28, 2009 | 09:39 PM
thanks. & you can say that again..
lol everything is broke lol
Originally Posted by Evolv3dEvo8
that sucks man sorry to see that
^^ ima she.
thanks
Old Sep 28, 2009 | 09:50 PM
reactionevo8's Avatar
you may need to repair the threads on the end of the crank where that flywheel bolt once resided as well,good luck
Old Sep 28, 2009 | 09:52 PM
ahah... awesome
Old Sep 28, 2009 | 09:54 PM
so now.. continuing the list lol
i need...
new valves lol
new head
pistons
oil pan
this aluminum plate lol
possibly a new clutch since the flywheel bolt was chillin.?
flywheel possibly?
pressure plate?
hmm.. anything else lol
oh, timing belt haha.
once again..
F- this CAR!!!
oh, and the stupid 0-ring they forgot to replace..
possibly new crank.
Old Sep 28, 2009 | 10:00 PM
rods.... pretty sure you banged up the bushings...
Old Oct 5, 2009 | 10:56 AM
bevolucion's Avatar
just get a used long block, avoid all the headaches of rebuilding that one
Old Oct 5, 2009 | 01:33 PM
EVO8emUp's Avatar
As long as the block is OK and no major parts are damaged. I wouldn't even consider a used longblock. You never know what you're getting into. You could end up with these or similar problems all over again. At least with this motor, you'll know exactly what the deal is.
Old Oct 5, 2009 | 02:37 PM
camarokilla's Avatar
its always nice to see some ladys get there hands dirty. but forget the used block BR stage 3 all day. if you need a head i have a used core laying around. just pm me
Old Oct 7, 2009 | 04:13 PM
the block is fine. and i heard the head is repairable.
your from chicago? i may consider the offer. how much and do u have valves as well?
Old Oct 7, 2009 | 05:13 PM
barneyb's Avatar
Well, I'd be taking a long hard look at the pistons. They could be okay. And if that is the case it simplifies things considerably.
