Clutch slipping????
Old Oct 18, 2003 | 01:49 PM
evoguy's Avatar
Clutch slipping????
Took my car to the track last night....got into 3rd gear and my exedy single plate started slipping, it only has 750 miles on it. It only did it when I shifted quickly, if I shifted slow it was fine. I did a 4000 rpm launch rolled off easy and then got on the gas second gear shifted at 6800 shifted nice and slow it was fine, went to 3rd shifted really quick and it slipped. It was fine again on the drive home, couldn't get it to happen again. Btw I only ran one time. 2.1 60 foot so I was taking it real easy just trying it out. I also got wheel spin in first after I got on the gas (clutch fully engaged).
I am curious do you guys think taking the restrictor out and bleeding the line will help this? It seems to me like the clutch didn't engage quick enough. Like there is air in the system or something, not allowing the clutch to engage quick enough.
Old Oct 18, 2003 | 05:05 PM
Fourdoor's Avatar
Have you removed the restrictor on the slave cylinder? If you still have the restrictor that could be your problem.
Keith
Old Oct 21, 2003 | 08:09 AM
sevensign's Avatar
Some may have their clutch worn out early...
Pls do check-up
