Fuel injector clips evo 8
Old Oct 5, 2009 | 11:51 AM
xcelr8's Avatar
Does anyone know where I can buy these metal oem clips? Or should I just go to mitsu?
Old Oct 5, 2009 | 11:52 AM
localtoys73's Avatar
probally could make a paperclip work
or go to mitsu not sure if they just sell the clip though
Old Oct 5, 2009 | 11:58 AM
TTP Engineering's Avatar
You cannot get the clips separately without buying the whole $1200 engine harness.
Old Oct 5, 2009 | 12:08 PM
xcelr8's Avatar
R U kidding? WTF. can they be made?
Old Oct 5, 2009 | 12:45 PM
ROGERV's Avatar
I made some out of a thin key chain ring.
Old Oct 5, 2009 | 01:25 PM
EVO8emUp's Avatar
Do you need all of them? I have a few.
Old Oct 5, 2009 | 03:21 PM
xcelr8's Avatar
yes I need all. cant find them anywhere
Old Oct 5, 2009 | 03:38 PM
ETS Michael's Avatar
You could always get the AEM quick release clamps. You would need to wire them in though. You might be able to buy a cheap aftermarket injector clip that has the wire in it. You could maybe try the junkyard and look for a 1G, 2G eclipse.
Thanks,
Michael
Old Oct 5, 2009 | 03:43 PM
WHTEVO's Avatar
The metal U shaped clips that go on the injector pigtail harness? If so, those can be bought for a few bucks from NAPA! Good luck.
Aaron
Old Oct 5, 2009 | 03:54 PM
DynoDude55's Avatar
You can get both from NAPA like Aaron mentioned above.
Plastic Injector Plug is NAPA part #071M
Metal Wire Clip is NAPA part #217417
Old Oct 5, 2009 | 03:56 PM
Good work people.
Old Oct 5, 2009 | 04:15 PM
KenMasters's Avatar
Carz FTMFW
Old Oct 5, 2009 | 06:37 PM
CO_VR4's Avatar
Old Oct 5, 2009 | 06:43 PM
xcelr8's Avatar
really appreciate it guys.
Old Oct 5, 2009 | 06:44 PM
phenem's Avatar
I bought these about 3 years ago when I put different injectors in because I was tired of loosing the clips too! Work perfect and cheap, they come in packs of 8 so you have a second set just in case!
http://www.summitracing.com/parts/MSD-2400/?image=large
Just cut re-solder and replace they are quick clips so they come off really fast and you never loose the clips!
