My evo is breaking up badly under wot help!
Old Oct 7, 2009 | 11:06 AM
dtmpower647's Avatar
Originally Posted by hoof hearted
Also--- how long have you owned the car?
I've owned the car for alittle over a year now
Old Oct 7, 2009 | 11:07 AM
And thanks forball the help so far guys
Old Oct 7, 2009 | 11:17 AM
rcheung's Avatar
I'm wondering WHY YOU CHANGED PLUGS?!?!?
Only time I've ever changed them is when I've had a problem...
Never just woke up and said "I think I'll change my plugs today."
This may help diagnose....
I change my plugs at every 3-5k if they're copper and every year if i use Iridium. Its a maintenance thing. I guess its a different kind of thinking when you drive a cadillac. Its almost like saying don't change the oil until it sludges up or don't change the brake pads until you can hear the wear indicators.
Old Oct 7, 2009 | 07:44 PM
hoof hearted's Avatar
So you know how the car reacts and are familiar with it as you didn't just buy it and inherit somebody else's problems....
You can make assumptions being a Cad is in my sig. but I think getting personal and saying I don't maintain my **** is pretty judgmental...
I have a lift IN MY GARAGE at my HOUSE..... (And sludgy oil lol)
Back to my diagnosis of your problem.....
1. If it had zero issues b4 plug change---- GET 4 NEW ONES and try it again as you may have gotten or cracked one. (Been there--seen that movie circa LSX motors...)
2. If all checks out still bad with the different plugs--- have a buddy come over and swap out his 1. COILS or next 2. MASS AIR METER/ SENSOR .
Hopefully one of these things will get you back up running strong
Oh... I'll buy your 3-5k mile plugs! lol
Show a little love.
Old Oct 7, 2009 | 08:59 PM
italianevo88's Avatar
Can anyone tell me when you need colder plugs or hotter plugs?
Old Oct 7, 2009 | 09:09 PM
VQChris's Avatar
Show a little love.
I think you took what he was saying the wrong way. I also change my plugs every 5,000 miles. Im sure I dont need to but I consider it basic maintenance. I think what he mean't is your probably not all that familiar with Evo's if your suprised he has changed his plugs. I dont know you or whether you do have knowledge about these cars so thats an assumtion .
Old Oct 7, 2009 | 09:26 PM
My prior mitsu experiences...
1985= 1980 Dodge Colt
1986= 1984 Dodge Colt GTS TURBO
1991= 198? Mitsubishi Tredia TURBO
1997= 1990 Eclipse GSX AWD TURBO
1999= 1991 Talon TSi AWD TURBO
2006= 2003 Evo
2009= 2003 Evo
Lol...I surprised myself with that list!
Just trying to help a 4g63 guy out... as I've seen a little....
Old Oct 7, 2009 | 09:34 PM
VQChris's Avatar
2006= 2003 Evo
2009= 2003 Evo
Well I sad assumtion
To the OP, I have also had a problem that sounds the same so I pulled out all my plugs and used dielectric grease on both ends of the plugs and it went away. This was like 4,000 miles ago.
Old Oct 8, 2009 | 01:27 PM
I got the problem fixes I re gaped the plugs to 25 and it runs like a champ. Thanks again for all of your help guys!
Old Oct 8, 2009 | 01:36 PM
evolution2186's Avatar
I was experiencing the exact problem. I checked the gap which was .28. I re-gapped to .22 and run perfect. I also run BPR8EIX which is the 1-step cooler plug. The gap still opens one in a while. Good luck friend.
Old Oct 8, 2009 | 01:38 PM
xRoguex's Avatar
lucky!
I had mine gapped at .022 and still got the bucking..
Coils are weak to the point of no firing above 20psi
Old Oct 8, 2009 | 02:30 PM
So it was the common problem... too much gap.
Old Oct 12, 2009 | 09:44 PM
Virgil072's Avatar
Curious, will throwing One Step Colder plugs on a stock car do anything hooky? Mine need to be replaced, and I got a little overenthusiastic and ordered NGK One Step Colders for my 05 GSR w/o doing my research. *DOH
Old Jun 7, 2010 | 11:15 PM
thomas.featsent's Avatar
so with all of the advices above, I am having the same problems got a .23 gap in my plugs with NGK plugs. Also running spark tech with cdi. Its breaking up at 6000rpm with boost at 37pounds. Fuel E85 new plugs new coils. AFR and timing are perfect so what I am gathering is to make gap bigger or smaller with spark tech I am thinking bigger. What is everyones input on this. If its that simple, well damn I am doing it right now!
Old Jun 8, 2010 | 12:16 PM
dpalo's Avatar
