ACD Lights
Old Oct 17, 2009 | 06:10 AM
blackdemon's Avatar
ACD Lights
I went to ohio with a friend of mine. As i was driving there it was dark raining and visibility was very very low. I got blocked off from my friend by a tractor trailer, as he then moved out of my lane there was a huge deer dead on the floor. I couldn't completely swerve out of the way to miss it so i ran over it from the passenger side, ripping my SE lip in half and making a nice hole in my licp coupler. I got to where i was going with a boost leak, my boy then semi fixed the coupler since we could not find one to replace it with. We then drove all the way back to NY 7HRs + The next day i decided to wash the engine bay and underneath of the car to remove the smell. After a few minutes all 3 ACD lights were on. Keep in mine the car was fine after i ran over the deer and all the way back to NY. When the 3 acd lights are on and i hit the acd button then turn off the car you will see that the setting is different but then after a few minutes all 3 lights come back on. What can be the problem? Acd Sensor? Relay? The car drives normal. It just botheres me that all 3 lights are on.
Old Oct 17, 2009 | 06:15 AM
tchouko's Avatar
danm dude sorry to hear that man...but have a shop check your ACD sensor...cause i dought it's the relay...GL buddy.
Old Oct 17, 2009 | 06:21 AM
blackdemon's Avatar
I think i have the code puller on my laptop Pat. Im going to try that today.
Old Oct 17, 2009 | 06:49 AM
amsevoixmrse's Avatar
Sorry to hear that !!! i hope its easy fix bro....
and no oil leaks ? oil levels are fine ?
Old Oct 17, 2009 | 06:51 AM
blackdemon's Avatar
No oil leaks at all. Other than the lights being on the car runs and drives absolutly normal.
Old Oct 17, 2009 | 11:07 AM
evo unknown's Avatar
may be a coincidence and there could be a relay problem. have you tried resetting the ecu (disconnecting the battery)?
Old Oct 18, 2009 | 06:41 AM
blackdemon's Avatar
bump
Old Oct 18, 2009 | 09:22 AM
evo003's Avatar
probably just a coincidence. Many things can cause those lights to come on. Mine was a bad pump but I've heard of it also being ABS wheel sensors or even fluid levels. Check out the multiple threads on here about the ACD
Old Oct 18, 2009 | 09:40 AM
Peteypab2133's Avatar
Take it to the dealer, have them check wheel speed sensors. Car is in tarmac mode even though all three lights are on. Mine does the same thing, and I am waiting for the sensor to come in.. its covered under warranty too as long as your car is in warranty of course
Old Oct 18, 2009 | 09:53 AM
bilbert 69's Avatar
I had the same problem it was a bad pump
Old Oct 18, 2009 | 05:56 PM
blackdemon's Avatar
How much is the sensor?
Old Oct 18, 2009 | 09:13 PM
If i recall i think the sensor is like $397.00 but i was being nebby and may have read wrong while she was tellimg me they were ordering it.
Hope and pray its not the pump. Those are $$
Try getting diagnostics done first
Old Oct 19, 2009 | 05:00 AM
evo003's Avatar
The pump is covered under your basic 60,000 mile warranty
Old Oct 19, 2009 | 08:40 AM
so is the sensor, they already ordered it under warranty. I assumed he has no warranty or was black listed. Best of luck
Old Oct 19, 2009 | 09:08 AM
my 3 acd lights became illuminated..i read the manual..and it says to bring it in
mitsu never actually found out what was specifically wrong. they determined it was a relay issue and replaced my acd pump. the bad pump is then sent away to mitsu engineers to work on.
