Is this a normal evo o2 sensor set up?
Old Oct 19, 2009 | 01:35 PM
EvoRinga's Avatar
sorry about the quality.. taken from my iPhone
Old Oct 19, 2009 | 01:38 PM
Bobster22388's Avatar
That does not look like the stock setup. Looks like an aftermarket AFR sensor that someone installed. The one on the right is the original sensor though
Old Oct 19, 2009 | 01:41 PM
EvoRinga's Avatar
okay, so shouldnt there be one before the test pipe too?
Old Oct 19, 2009 | 01:44 PM
Yes, there should also be one before the test pipe
Old Oct 19, 2009 | 01:46 PM
EvoDan2004's Avatar
yep. which is all the way up on the o2 housing. you will see it when you pop the hood
Old Oct 19, 2009 | 01:48 PM
Thanks EvoDan, for some reason I couldn't recall where that one was haha
Old Oct 19, 2009 | 01:55 PM
EvoRinga's Avatar
so if I space out the o2 on the right with the CEL fix that should shut off the CEL
Old Oct 19, 2009 | 01:59 PM
EvoRinga's Avatar
my sticker expired and I need to get a sticker, I know someone who will pass it with no cat but not with the CEL on
Old Oct 19, 2009 | 02:02 PM
Yes, that should fix your CEL
Old Oct 19, 2009 | 02:06 PM
EvoRinga's Avatar
Great, thanks a ton. Ill let you guys know when it comes in tomorrow or wednesday
As long as that is what the CEL is on for, do you know what codes your throwing?
Old Oct 19, 2009 | 02:07 PM
EvoRinga's Avatar
oh wait, hmm doesnt the sensor on the right already look spaced?
Old Oct 19, 2009 | 02:15 PM
The one on the right does appear to be spaced out some actually now that I look at it more closely
Old Oct 19, 2009 | 02:16 PM
buchnerj's Avatar
Not a stock setup as other have stated. Sensor on right looks like the stock sensor, and the one on the left looks like a wideband plugged into a bung someone home welded. Get a spark plug non fouler or maybe two and screw them into one another, I drilled mine out to have a higher diameter flow too, because I kept throwing codes even after spacing it. Been going strong for over a year now CEL free.
Old Oct 19, 2009 | 02:18 PM
EvoRinga's Avatar
okay, Ill try that when it comes in in a few days, thanks, Ill update when I can..
