Best Tool to Install/Remove Valve Sten Seals?
Old Oct 21, 2009 | 10:47 AM
nirvevo's Avatar
OK, I know about the MD998737 Tool to install the valve stem seals, but what about removing them?
Does the 4g63 (Evo VIII) require a special "narrow aceess valve stem seal pliers" or will a standard size work?
Also, most mfg's say you can use the VSS Pliers to both remove and install the seals ... anyone do that successfully?
thanks
Old Oct 21, 2009 | 11:51 AM
blueshark123's Avatar
I'd assume regular pliers would do the trick. Not sure on the 8s though
Old Oct 21, 2009 | 12:45 PM
nirvevo's Avatar
Thanks,
... but I'm looking for hands on knowledge.
I intend to use specific Valve Stem Seal Pliers, I'm just wondering whether the 4G63 requires the special narrow version of that tool.
Old Oct 21, 2009 | 06:08 PM
thebluesky's Avatar
Don't waste your money on a special tool for just the seals. I just rebuilt my head and pliers worked just fine. They come off without issue.
Old Oct 21, 2009 | 09:27 PM
nirvevo's Avatar
Well if regular pliers worked, I guess the regular VSS pliers ought to work.
I like using the right tool for the job, at least most of the time.
anybody else have experience with this removal and install process?
Raceghost
Mar 11, 2019 01:04 PM
ugakirk
For Sale - Wheels / Tires
May 25, 2017 07:04 AM
0to140in9
Oct 20, 2016 08:02 PM
bostonhatcher
May 21, 2015 06:07 AM
1QYK9
64
Feb 29, 2008 09:39 AM
