Ecu code p0603 (help)
Old Oct 23, 2009 | 01:37 PM
-Evo Aaron-'s Avatar
Question Ecu code p0603 - Fixed by swapping an 03 ecu in
Fixed issue- Picked up a used 03 Ecu and swapped it in
Old Oct 23, 2009 | 01:54 PM
Heres what i found online about it
P0603 - PCM KEEP ALIVE MEMORY (KAM)
The onboard computer, or Powertrain Control Module (PCM),is the brains of the engine control system, so when the brain is not functioning correctly neither is the engine or anything else that the microprocessor controls - which may include the charging system, transmission, various emission controls and communications with other onboard control modules. Once a diagnosis has been made (and we emphasize the word diagnosis), then and only then should the PCM be replaced.
Onboard Diagnostic (OBD II) diagnostic trouble codes that typically indicate a fault with the powertrain control module include:
P0600....Serial Communication Link
P0601....Internal Control Module Memory Check Sum Error
P0602....Control Module Programming Error
P0603....Internal Control Module Keep Alive Memory (KAM) Error
P0604....Internal Control Module Random Access Memory (RAM) Error
P0605....Internal Control Module Read Only Memory (ROM) Error
P0606....ECM/PCM Processor
P0607....Control Module Performance
P0608....Control Module VSS Output 'A'
P0609....Control Module VSS Output 'B'
P0610....Control Module Vehicle Options Error
If you see any of these codes when diagnosing the vehicle with a code reader or scan tool, it may mean the PCM has failed and must be replaced. Additional diagnostic tests will usually be necessary to confirm the problem is really the powertrain control module and NOT something else. Refer to the OEM diagnostic charts for what these tests are. Usually it involves checking certain inputs to the PCM to see if it outputs the correct response. No response or an incorrect response usually means the PCM is defective and needs to be replaced.
All too often, technicians tend to blame that which they understand least. If an engine is not running right and the cause is not obvious, they may blame the computer. Throwing parts at a problem in an attempt to solve it may be good for the parts business, but when a customer brings a PCM back because it failed to fix their problem, nobody wins. Warranty returns on complicated and expensive components like powertrain control modules are an ongoing problem that costs everyone money.
UNNECESSARY POWERTRAIN CONTROL MODULE RETURNS. Over 50 percent of PCMs that are returned under warranty (either because the PCM failed to fix a performance problem or because the engine did not run properly after it was installed) have nothing wrong with them! So it is obvious a lot of people are swapping computers to see if a different PCM will fix their problem.
The trouble with returns is if the PCM has been on the car, you have no way of knowing if it is still "good" or not. Somebody may have crossed up some wires, zapped the PCM with too much voltage or who knows what? The computer needs to be tested and verified before it can go back on the shelf and be sold to somebody else.
Unfortunately, there is no easy way of doing that in a parts store. The PCM has to be hooked up to a sophisticated simulator that exercises all of the computer's input and output circuits to make sure it works correctly - which means the PCM has to go back to the supplier, be retested, and if no fault is found, repackaged and put back into stock.
Be warned, though, that many parts stores have a policy of "no returns or refunds on electronic components."
WHY DID THE POWERTRAIN CONTROL MODULE DIE?
One way to reduce the risk of PCM warranty problems is to find out why the old PCM died. Determining the cause of death may not always be possible, but it may be essential to prevent the same thing from damaging the replacement PCM in some cases.
PCMs typically fail for one of two reasons: voltage overloads (often due to a short in a solenoid or actuator circuit) or environmental factors (corrosion, thermal stress or vibration). If the shorted solenoid or actuator is not found and repaired, the voltage overload it creates may damage the replacement PCM, too.
As for environmental factors, water is the main thing to avoid. If water gets inside a PCM, it can short circuits and set up irreversible corrosion that ruins electronic connections. Most remanufacturers will not even attempt to repair a PCM if the vehicle it came out of was submerged in a flood. Replacement is the only option. Thermal stress and vibration can form microcracks in circuit boards (which are repairable). This often has more to due with the ruggedness of the circuit design than operation factors in the vehicle itself.
ACCURATE POWERTRAIN CONTROL MODULE IDENTIFICATION
Because there are so many different PCMs, accurate identification of the PCM and its correct replacement is absolutely essential to prevent unnecessary returns. Many PCMs appear to be exactly the same on the outside (same sized box and connectors) but may be wired or calibrated differently inside.
If the wrong PCM is installed in a vehicle, it may run but probably will not run well. Close enough is not good enough when it comes to replacing PCMs. It must be the correct replacement for the application.
Accurately identifying the PCM requires not only the vehicle year, make, model and engine size, but also the OEM part number on the PCM itself. Most supplier catalogs list replacement PCMs both ways. So if in doubt, always refer to the OEM number on the PCM and look it up in the suppliers cross reference index to find their replacement part number.
The calibration chip and PROM contains the programming instructions for the vehicle application. That is why it usually does not come with the replacement PCM. There are too many different possibilities. On many newer vehicles, flash memory or "EEPROMs" (Electronically Erasable Program Read Only Memory) are used. If the replacement PROM is not properly programmed for the application, it must be reprogrammed after it has been installed.
Unfortunately, the ability to do this type of reprogramming is not readily available to the aftermarket. The car makers do not want aftermarket technicians messing around with the calibration of their onboard computers because they are afraid doing so may alter emissions or performance. But that is another issue. One such example is Chrysler transmission modules. They must be reset with the factory DRB scan tool and dealer codes to set the "pinion factor," which controls the operation of the speedometer.
REMAN POWERTRAIN CONTROL MODULES
Because a powertrain control module can be very expensive to replace, almost all aftermarket replacement PCMs are "remanufactured" units. A PCM is not rebuilt in the same way that an alternator or water pump is rebuilt because there are no mechanical parts that wear out. Remanufacturing in this case usually means testing the powertrain control module, isolating and repairing any faults that may be found, then retesting the powert5ain control module to make sure everything works correctly.
A remanufactured PCM is typically sold one of two ways: on an exchange basis from stock, or on a custom rebuild basis. If a particular PCM is not in stock or is unavailable, you may be able to send an old PCM to a remanufacturer for repair. Turn around time is typically a few days and the cost is about the same as an exchange unit except there is no core charge). The hard part is finding a remanufacturer who can test and repair your powertrain control module.
Some PCMs, though, may not be repairable. As we said earlier, most remanufacturers will not even touch a PCM if it came out of a flooded vehicle.
PCM REPLACEMENT TIPS
Replacing a PCM is essentially a matter of swapping boxes. Accessibility can be a problem on some vehicles because the PCM is often buried under or behind other components in the instrument panel, climate control system or console. Some are located under a seat and require removing the seat.
Regardless of the PCM's location, though, one thing you should do prior to removing the old PCM and installing the replacement PCM is disconnect the battery.
Once the PCM has been installed and reconnected, the battery can be reconnected, too. But the job is not done yet. Many PCMs have to undergo a "relearning" procedure after they have been installed or if they have been disconnected from the battery. On some newer vehicles, a scan tool may be required to reprogram the PCM and to reset the anti-theft system.
On some applications, there may be a specific relearn procedure for establishing the base idle speed and other operating parameters. On others, it may be necessary to take the vehicle for a short test drive so the computer can adjust itself. The exact requirements will be spelled out in the vehicle service manual. The best advice here is to test drive the vehicle after the powertrain control module has been installed. A short drive cycle that includes going over 35 mph will usually reset most PCMs so they will operate properly.
The powertrain control module will also continue to learn and make small adjustments to the fuel mixture and other functions over time as the vehicle accumulates miles. If the PCM also controls the transmission, it may take awhile to relearn the driver's habits so the transmission may not shift exactly the same as before until this occurs.
Finally, if the Malfunction Indicator Lamp (MIL) or Check Engine light comes back on after the PCM has been replaced, it means there is still a problem with the vehicle. The fault is probably NOT the PCM, unless the fault code is for an internal PCM fault. The presence of fault codes means additional diagnosis is required to identify and repair the fault. And until the real problem is found and fixed, the PCM may not function normally.
If the engine control system is not going into closed loop, chances are the coolant sensor or oxygen sensor may not be working properly. If spark timing seems to be over advanced or retarded, the problem may be a faulty MAP sensor, misadjusted throttle position sensor or overly sensitive knock sensor. And if nothing seems to work right, low charging voltage due to a weak alternator or poor battery connections may be the fault.
Remember, a powertrain control module needs all its sensor inputs, proper battery v
Old Oct 23, 2009 | 11:10 PM
no one has any helpful info on how to get this fixed?
my car is out of warranty...
Old Oct 24, 2009 | 12:45 AM
RoadSpike's Avatar
Have you tried just clearing it and see if it comes back?
Any piggy back unit connected?
Checked pin 80 (backup power supply) for voltage when car is OFF.
Old Oct 24, 2009 | 01:59 PM
I have cleared it multiple times and it comes back instantly,
no piggy back unit
not sure how I would test the last thing you listed
Old Oct 24, 2009 | 10:00 PM
RoadSpike's Avatar
no piggy back unit
Like all backup 12 volt power sources with a circuit tester OR a multimeter.
It could be an internal ECU thing too so its really unknown. Do you have any ecu modifications done? If you can't figure it out and it runs fine it may just be possible to shut off the code instead.
Old Oct 24, 2009 | 11:16 PM
heavens turbo's Avatar
check the hot wire to the ecm, (get a wiring diagram and pin diagram), bad battery/connections, loose wire or damaged pin on the harness/ecm, bad ecm. good luck.
Old Oct 24, 2009 | 11:31 PM
justa4banger's Avatar
Didn't your car have a AEM STANDALONE??? Maybe when they switched it back to stock ecu they didn't do something right
Old Oct 25, 2009 | 02:40 PM
it did, but it was removed before i bought the car(and the owner just gave it to me but i sold it on here) I do have an 05 ECU and my car is an 03.
How could i just "get rid of it"? the car runs fine no issues there, Im running bolt ons cams and an E85 tune, but its always had this code.
I know that right now on my harness, the connector for the stock boost solenoid was Cut off so those wires are just open sitting there..
i would have to check other stuff, my car's previous owners really Messed her up
Im looking for a stock boost solenoid so i can reconnect it and get rid of that code too..
Old Nov 10, 2009 | 04:25 PM
crewdawg130's Avatar
I just got that code for changing disableing the immobilizer.... any help??????
Old Nov 10, 2009 | 07:33 PM
idk man, still nothing on mine, i have not found anything out,
but havent done much trouble shooting
Old Nov 10, 2009 | 08:27 PM
EvoRob22's Avatar
Resetting Keep Alive Memory (KAM)
It may be necessary to reset the KAM in the PCM to the default setting after a Diagnostic Trouble Code (DTC) causes a engine or vehicle warning light. Other conditions may not produce a warning light, such as ethanol and poor performance conditions related to fuel mixtures that may warrant a reset. KAM creates adaptive learning contents such as idle speed, refueling event, and fuel trim.
For instance, after refueling and driving a short distance, I noticed a big decrease in FE. This has occurred a few times and is from a gas mixture that used oxygenates (ethanol), sometimes referred to winter gas. I no longer fill up at Citgo stations as a result.
Due to the fact that % of alcohol or oxygenates are not as combustible as gasoline, the oxygen sensors send a message to the PCM that there is a lean fuel trim and it makes an adjustment for a richer air/fuel mixture. The PCM alters the air/fuel ratio maps at the different RPM’s and engine load points, and the KAM stores this data as the long term fuel trim. There is not much you can do at this point other than burn the entire tank of gas. Once you refill with straight gas, it may take a few tanks for the PCM to adjust all the long term fuel trim maps stored in the KAM for each RPM/Load point. This means you will be getting a richer air/fuel mix at closed loop modes and your MPG will be reduced accordingly. In the past, I didn’t understand why my FEH continued to get poor MPG after I replaced the fuel with straight gasoline. After refueling a few times, my MPG returned to normal because the PCM eventually readjusted the air/fuel mixtures at all RPM’s and engine load points in the KAM air/fuel maps.
Any time the FEH has had a condition that may have altered KAM, a reset to the default mode can be done by using one of two methods. Adaptive learning contents such as idle speed, refueling event, and fuel trim are included in the reset of KAM. To clear the continuous DTCs in the PCM and have it reset the emissions monitors information, is also part of a KAM reset. Both can be useful in post repair or a big change in driving conditions. KAM can be reset by a diagnostic tool or by disconnecting the 12V battery ground cable for a minimum of 5 minutes.
After the KAM has been reset, the vehicle may exhibit certain driveability concerns. It is necessary to drive the vehicle to allow the PCM to learn the values for optimum performance. My recommendation would be to reset the KAM after the vehicle is warm and drive the most fuel efficient way possible afterwards. Always remember that KAM is reset when the battery is disconnected for more than 5 minutes.
This is for Ford, but disconnecting the battery for 5 minutes should still reset it. I think that maybe because your car is an 03 and you have an 05 module in it, somehow the module can't learn your strategies. I don't know if its because there are different sensors, timing, or what. I mean you had your car tuned with this code in the computer?
Old Nov 11, 2009 | 04:20 PM
EvoRob22's Avatar
I did some more research. There are only 3 things that can cause this issue.
1) Your KAM PWR Circuit is open. Get a wiring diagram for the ECU and find out which pin is your KAM PWR Circuit. Then get a DVOM and measure voltage with the read lead on the Pin and the black lead on ground. You should have voltage. If not you have an open on that Circuit.
2) You fried the KAM in your module. Replace Module.
3) A sensor your KAM uses is not installed on an 03, but is installed on an 05. I don't know what it would be, but you would need to replace the module.
Put an 03 Module in it would be your best bet.
Old Nov 23, 2009 | 04:27 PM
thank you guys, (by module you mean an 03 ECU right...?)
or is the PCM separate from the ECU
Old Nov 23, 2009 | 06:55 PM
EvoRob22's Avatar
PCM and ECU = same thing .
