Lets play a game, whats wrong with my engine?
Old Oct 24, 2009 | 04:10 PM
shrtstuff89's Avatar
so lets play a game. by the short description given and the pictures, tell me exactly whats wrong with the car.
car was running fine, however it got the famous misfire code on cylinder 3 when in 5th gear. then about a week before garaging it i started getting tons of white smoke out the exhaust. checked the oil and it was low and black, so did an oil change and turned the car on. after about a minute the smoke came back....
went to change spark plugs, all were fine minus cylinder three, which looks like this:
upon taking the exhaust manifold off, cylinder 3 looked like this:
and did a coolant compression test which came back fine so it shouldnt be the head gasket
so, lets play "whats wrong with it"
Old Oct 24, 2009 | 04:13 PM
Evo IX MR's Avatar
Usually when a plug is toast like that so is the cylinder that it fires for. Looks like detonation and the white smoke it probably blow-by (oil).
Old Oct 24, 2009 | 04:30 PM
eag36's Avatar
You've obviously got oil in cylinder 3, and it's somewhere in the head as you don't see it in the others.
You've got to take the head off to find out and fix what's wrong anyway, so why bother guessing? Grab the wrenches. You've got a bad head gasket, valve guide, piston rings... etc.
Just because you did a coolant compression test, doesn't mean the head gasket is fine. If you want to test it more... do a cylinder compression test which is going to tell you that #3 is low, and you'll need to take the head off. So you might as well do that now.
Old Oct 24, 2009 | 04:43 PM
JohnnyTSi's Avatar
Valve Guide Seals?
Old Oct 24, 2009 | 05:04 PM
was told it would be more hassle to get down to the head myself than to just hook everything back up. all id need to do is take off my timing belt then pull off the head and its bolts. but was told if its the piston rings or anything else, itll be 10x more work than what ive already put into it. so, sadly gonna have to just put it together and take it to the ****ty *** lemon dealer and see what theyll do. if not take out another loan to get it fixed. :\
Old Oct 24, 2009 | 05:14 PM
warp9's Avatar
Before you took it apart I assume you tried a fresh set of plugs to see if that helped?
Old Oct 24, 2009 | 07:32 PM
that i did. and started it back up seemed fine then after a couple minutes started smoking pulled the plug and wasnt caked with **** but was alrdy blacked out.
Old Oct 24, 2009 | 09:55 PM
Force-Fed Performance's Avatar
Do compression, sounds like you got possible bent/burnt valve. Does it sound funny idling? like a subaru. First step is compression
Old Oct 24, 2009 | 09:57 PM
sparky's Avatar
First, do a compression test. If cylinder #3 is 14 PSI< than the other three cylinders, or less than 130 PSI, then do a leakdown test. But, I lean toward what JohnnyTSi said....valve guides and seals and hopefully not rings. Good Luck!
Old Oct 24, 2009 | 10:04 PM
TTP Engineering's Avatar
Sounds like a broken piston cracked or compressed/broken ring.
Old Oct 29, 2009 | 02:35 PM
1badmr's Avatar
dude i had the same problem, my motor is being tore apart today ill let you know here shortly
Old Oct 30, 2009 | 09:05 AM
any info yet on your car?
Old Nov 2, 2009 | 12:28 PM
1badmr's Avatar
correct broken piston
Old Nov 2, 2009 | 12:32 PM
supeazn's Avatar
game over i guess LOL. GL
