Tcase question!! HELP!
Old Oct 25, 2009 | 03:38 PM
Evoluvin's Avatar
Well i picked this Tcase up for my 03 evo for $300 but there is a chip where you put it into the transmission it slides in the trans and everything fine but im afraid it is going to leak where there is a chip in it.... i think once i put the O-ring around it it should be fine but i want some more opinions also do you think i could just swap the guts out of this tcase and put them in mine.... let me know... help is GREATLY appreciated!!!! Here is the best pictures i could get!
Old Oct 25, 2009 | 04:48 PM
sho669's Avatar
that looks a little sketchy if you know someone that can weld aluminum then your set! local machine shop maybe? either that or you could use some of that magical JB weld! works wonders!
Old Oct 25, 2009 | 04:51 PM
Evoluvin's Avatar
lol ok thanks dude..... anymore input would be greatly appreciated
Old Oct 25, 2009 | 04:56 PM
thedru13's Avatar
IDK not sure it will leak. The O Ring should seal it up. I would not put JB Weld on that.. I would say as long as its not to jagged or going to rip the o ring you should give it a go.
Old Oct 25, 2009 | 05:03 PM
Evoluvin's Avatar
ok thanks... i wish i had a better picture.... but i think i should be ok it isnt to jagged and theres no way it would rip to O-ring... but my girlfriends dad welds but he doest have an aluminum welder... i culd always just take it to a machine shop and get a quote.... also for $300 i couldnt go wrong it only has 35K on it.... mine is SHOT!
Old Oct 25, 2009 | 05:04 PM
thedru13's Avatar
Not sure what you would weld in there and get it perfect. I would let it go. If its not sharp then i would put it in. Drive it slow around the block and see how it performs.
Old Oct 25, 2009 | 05:12 PM
Evoluvin's Avatar
ok thanks for the input!!!!!!!^^^^^^^^
Old Oct 25, 2009 | 05:18 PM
slow/ass/rs's Avatar
i got a non acd t case for sale if you want it 30k on it make me a offer
Old Oct 25, 2009 | 05:43 PM
06ravenmr's Avatar
i wouldnt put that in there looking like that.... but thats just me... ud always be second guessing it and it will be on the back of ur mind all the time
Old Oct 25, 2009 | 06:14 PM
sho669's Avatar
looks like some of you have never had to fix anything...you fill the cracked area with the weld and grind it down to the shape you want it. convertional welding works but the jb weld is easier and less expensive to work with. sometime you have to fix stuff to save money...thats why you got it cheap right? gotta make due with what you have.
Old Oct 25, 2009 | 06:20 PM
Ev0ikon's Avatar
if the lining surface under the oring is not chipped you will be fine.
Old Oct 25, 2009 | 06:49 PM
fast2go's Avatar
How many miles did you get out of the stocker and what caused it to go out.
Old Oct 25, 2009 | 06:50 PM
thedru13's Avatar
Yah well for us that have fixed many things on the cheap.. You learn when and when not to use JB weld. For me this would be one of those situations..
Again I would not worry about this. I would just put it in the car.. Its before the O Ring so it will seal..
Old Oct 25, 2009 | 06:54 PM
Evoluvin's Avatar
yeah its not chipped under the Oring but right before.... the Oring goes on right behind it.... i might just put some axle grease on it....
Old Oct 25, 2009 | 06:56 PM
Evoluvin's Avatar
I got 80K or so out of the stocker and i don't even launch the car! I think i launched it like 10 times for the first 1.5 years i owned it and now Ive had it for over 3 years so i haven't launched it for over 1.5 years and i had the fluids changed almost 15K ago.... so idk....
