Bov ?
Old Oct 28, 2009 | 09:43 PM
grizly3610's Avatar
Bov ?
I was wondering if I could benifit from an aftermarket bov? I am currently on the stock one and am running 23psi of boost. Is there any pros or cons using the stock bov? any help appreciated.
Old Oct 28, 2009 | 09:46 PM
detroit pistins's Avatar
the stock ix bov is known to hold boost well upto 25 psi, past then, some of them tend to leak, so at ur stage, u should be fine!
save ur money toward a ported tb and in manni. gl!
Old Oct 28, 2009 | 10:51 PM
malonejr2000's Avatar
you got an evo 9 your good if you had an 8 id say yeah
Old Oct 29, 2009 | 09:27 PM
grizly3610's Avatar
Thanks for the info! So im good untill i go over 25PSI?
Old Oct 29, 2009 | 09:50 PM
i just looked at your mods and have to change my opinion...for what all you have and the turbo you got you should go with a tial BOV man...i wouldnt trust the stock one you have with how much power your throwing down man...
Old Oct 29, 2009 | 10:01 PM
fugiwara's Avatar
Don't count on that, I bought a IX DV/BOV and it didn't hold 23psi, also stock IX bov has partial surge at partial throttle, I've heard it on 2 evo IX.
Old Oct 29, 2009 | 10:03 PM
dxbtune's Avatar
From: I'm Canadian living and working in Dubai/Kuwait/Bahrain
ibtl
Old Oct 29, 2009 | 10:07 PM
EvoLutionized8's Avatar
Are you planning on going VTA?? or recirculate again?? It will make a big difference since you're running stock ecu if you go VTA like a Tial.. If you are looking to go more than 25psi as noted above, then would be recommended to get a better BOV.. Im not going to mention which ones.. Just do a search and you'll see plenty of recommendations..
Old Oct 29, 2009 | 10:43 PM
grizly3610's Avatar
Would it be better to recirculate or go VTA? sorry im stil a newbie
Old Oct 29, 2009 | 10:56 PM
jeri534's Avatar
get an APS twin vent
Old Oct 30, 2009 | 12:03 AM
chaotichoax's Avatar
you can benefit from searching
closed...
