coils keep burning??? need help??
Old Oct 30, 2009 | 04:19 PM
Willsredix's Avatar
Ok so i have an evo ix and one morning i started the car and it had a huge misfire problem, checked the plugs two were bad so i replaced them. then i went to start the car and still have the misfire problem. so then i found out one of my coils was bad so i replaced them with the OKD coils, then i started the car again and one of the coils started to smoke and was really hot!!! so i think my engine wire harness might be messed up some where??
Old Oct 30, 2009 | 04:57 PM
hotdog's Avatar
Are you running a Twin Power DLI, by chance? When mine bit the dust on my 8, it ended up being that; bypassed it and it stopped eating coils, until I replaced it. Faulty unit I'm assuming.
Of course, if you're not running one... nevermind
Old Oct 30, 2009 | 04:59 PM
Piro Fyre's Avatar
I had a coil imploded on me before. Found out it wasn't grounded properly. Check the harnesses to see if it's connected to the chassis or the block.
Old Oct 30, 2009 | 05:02 PM
_mcjonnyp's Avatar
check the harness for loose grounds, loose connections or fried relays
Old Nov 1, 2009 | 04:52 PM
Willsredix's Avatar
ya i have the HKS DLI on there but i took it off when i started to have the problem, i also started taking apart the harness everything look good and i ran new power and trigger wire not ground and it was still misfiring. i guess ill have to try the ground too! i was also thinking it could be maybe be the injector driver or maybe the ecu is taking a fart?
