VP Imports vs Q16? Anyone made a back to back dyno test?
Subscribe
Nov 6, 2009 | 10:10 PM
Do they need the same volume/pressure?
which is better?
Reply 0
Nov 7, 2009 | 07:30 AM
Import will make more power due to it's higher octane. I think import is over 120 octane. They are both oxygenated leaded fuels. Import will make more power since you can run more boost and timing with a higher octane but how much exactly would depend on your set up. On a 35r car i think it would be marginal.On something a little larger like a 6765 or 42r that little extra timing and boost would make a larger improvement to warrant running import over Q
Reply 0
Nov 7, 2009 | 10:06 AM
cool
Anyone did a dyno/track test on vp imports vs Q16?
I have 2 modified walbros and -8 fuel lines and I want to know if its enough to support VP imports?
Reply 0
Nov 7, 2009 | 12:22 PM
it will be able to support vp and q16. its not like runing e85 where it requires more fuel. vp and Q are both just a leaded gas just vp is higher octane.
Reply 0
Nov 7, 2009 | 12:24 PM
ohh and how do you like that 6262? im thinking about geting a 6235 for my setup.
Reply 0
Nov 7, 2009 | 04:20 PM
Mate I think you fine to run either.
Don't forget tuning on both fuels you run leaner probably closer to 12:1 I think. As previously mentioned it's not like e85 that you need massive amounts of fuel to run high boost.
In addtion if I am not mistaken import is mega expensive like 100 dollars plus for a 5 gallon drum when q16 is closer to c16 money around 75 I think...
Reply 0
Nov 8, 2009 | 02:47 AM
E85 FTW!!
the poor man race fuel..
Reply 0
Nov 8, 2009 | 03:32 AM
VP import obviously gonna make more power but for the price it costs.. its not even worth it in my opinion. Why not try a mix of e85/q16?
Reply 0
Nov 8, 2009 | 08:40 AM
import will make more power but require more fuel, example... higher IDC
Reply 0
Subscribe
