Low oil pressure @ idle
Old Nov 7, 2009 | 06:50 PM
Murf's Avatar
Ok did a rebuild on the bottom end new crank acr race bearings, manley rods, ross pistons 9.0:1 compression. New oil pump and complete gasket kit and ams bal. shaft delete kit (race).
primed oil and fuel..no problems...car started easy as pie 3 cranks. Ran for a couple of minutes then the oil light came on..turn it off check oil...low from it filling the system. added oil back to full. started fine ran for a couple of min again then oil light on again. checked oil and its full. check for leaks...none bone dry. start again..idle oil light on...give a little gas goes off at 1300rpm..checked that twice then shut it off..checked for leaks again..bone dry..do not want to start again until I can figure it out. any ideas would be appricated. Oh the oil pressure sender in block is new as well.
Old Nov 12, 2009 | 06:16 AM
Murf's Avatar
solved and fixed.
Old Nov 22, 2009 | 07:06 PM
evoviiiem's Avatar
So what did ya do?
Im having the same problem right now, well just the oil light coming on in idle and going away in throttle. im new to the 4G63, only minor bolt ons other then the arp head studs and buddy club cams. just wondering what ya did to fix it.
Old Nov 26, 2009 | 11:25 PM
javicracer's Avatar
if the rpm drop belove 800, 700 the light will came on!
Old Nov 30, 2009 | 08:55 PM
LCS's Avatar
LCS
Originally Posted by Murf
solved and fixed.
What did you do?
Old Dec 1, 2009 | 06:37 PM
still*boostn's Avatar
oil pressure sending unit!!!!!!!! its an easy $6 fix.
youll just have to get one of your spaghetti arm friends to fix it for you,.. a B to get to. right above the transfer case.
Seach and youll find write ups with pix,... GL
Old May 28, 2017 | 12:39 PM
KABZAZKABZA's Avatar
solved and fixed.
What was the problem. I got Same issue. Thanks
Old May 29, 2017 | 01:11 PM
RazorLab's Avatar
You bumped a eight year old thread and the OP you quoted hasn't even logged into Evom for three years.
onlynamenotused
15
Oct 13, 2018 11:48 AM
Braineater6
11
Aug 12, 2017 12:39 AM
Ef8b16
50
May 8, 2017 08:56 AM
ISPEVO8
Feb 27, 2017 07:01 PM
khoyer
Dec 6, 2016 10:00 AM
