Bled clutch; now pedal is dead and down to the floor
Old Nov 9, 2009 | 07:51 PM
harrisonk531616's Avatar
I've been having a werid spongey pedal for the past two days; So i just got home from school and i bled the clutch...with a vacuum bleeder that hooks up to a air compressor. The fluid was very dark, and it looked like there was alot of resistance when the tool was sucking the fluid out...then i heard the vacuum free up, so i thought it was done...when i went into my car i saw the pedal on the floor...and no matter how many times i pump it, its down to the floor, no pressure at all.
The clutch was replaced 3k miles ago.
Bad slave?
Old Nov 9, 2009 | 08:08 PM
WickedWhtMR's Avatar
Did you make sure that the fluid didnt drain all the way out the back of the brake master cylinder. I made the mistake of only looking at the front of the master cylinder not noticing that that fluid was draining out of the rear section of the reservoir.
Old Nov 9, 2009 | 08:16 PM
FutureNoob's Avatar
bleed again.
Old Nov 9, 2009 | 08:21 PM
4G63 T's Avatar
chk. for leak
Old Nov 9, 2009 | 08:27 PM
FutureNoob's Avatar
bleed again with someone watching the res.
4RETECH's Avatar
Bleed again. Top off all fluid and start with the master.
Good Luck.
Old Nov 9, 2009 | 08:38 PM
FutureNoob's Avatar
no comment
Old Nov 9, 2009 | 08:47 PM
Originally Posted by FutureNoob
no comment
What? I use super blue fluid. The reservoir has a divider in it. The fluid that the clutch master uses in the half of the reservoir. If your using the power bleeder in the front of the car you dont see the fluid getting low unless you walk around and look at it from the drivers side.
Old Nov 9, 2009 | 08:52 PM
EvoRob22's Avatar
Agree with poster one. Bleed again and make sure the fluid stays full and no air gets in the system.
Old Nov 9, 2009 | 08:53 PM
TTP Engineering's Avatar
You have to constantly refill the reservior while bleeding it or it will pick up air again.
Old Nov 9, 2009 | 08:57 PM
buchnerj's Avatar
+ to everyone. Sounds like air in the system. Refill and keep an eye on the fluid level.
Old Nov 10, 2009 | 04:44 AM
where is the other res? I thought the clutch master only gets the fld. from the brake master...all i see is one hose connecting from the brake fld. res. to the clutch master..
Old Nov 10, 2009 | 05:01 AM
AJSS's Avatar
Hey man had the same problem a week ago well i was driving around until suddenly my clutch pedal just dropped dead. I took the car to my mechanic he simply pulled out a pin from my clutch pedal it was worn out and there was a plastic ring that fit on it that was broken replaced it and off i went everything was good as new check this out you might have the same problem.
Old Nov 10, 2009 | 05:02 AM
MR Turco's Avatar
there is only one reservoir. The Brake MC reservoir feeds the clutch MC.
Old Nov 10, 2009 | 06:34 AM
Kracka's Avatar
There is a small divider in the reservoir and its very small so the clutch can run out of fluid very quickly. While bleeding keep the reservoir filled to the very top (past the max line) into the neck.
