Hard to shift question...
Old Nov 15, 2009 | 11:01 PM
Sideck's Avatar
Hi,.. im going to replace my clutch with quartermasters or competition clutch (twin disk)
but right now i have a problem with my clutch and i want solve the problem before change the clutch... its a personal goal..
when i bought my evo come with stock clutch.. and i never had any problem on wot shifts... one day i burned my clutch and i get an ACT Clutch...
i install act clutch with gruppe-s flywheel, gruppe-s steel clutch line, and amsoil tranny oil, now i have royal purple max-gear...
i bleed my clutch line and adjust the pedal... but after the ACT installation i lost my butter shifts... i have alot problems on 4th gear wot shift.... not lock out, not grind.. only i can´t go to 4th gear if i made the shift quickly.. i can go in any gear but is very hard... with the stock clutch every gear was like a butter....
do you think is adjust problem, slave cylnder problem, bleed problem or fluid problem???
the clutch works excellent, never slip.. but im tired to fail gears on races...
thanks!!!
Old Nov 15, 2009 | 11:48 PM
dude's Avatar
None of the above. How about a heavy clutch.
The mini-twins have far less inertia, and you can shift faster. But they are noisy and are more "on/off" in nature.
Old Nov 16, 2009 | 11:50 AM
Sideck's Avatar
bump!!!
Old Nov 16, 2009 | 02:57 PM
moevo9's Avatar
I have a act hdss and i have the same problem shifting into second and third gear.
Old Nov 16, 2009 | 05:29 PM
monkey_187's Avatar
I heard of many problems like this with this clutch, you should of gone with an Exedy twin. Thats all I used cause it was the best for me, I was pushing 470.
Old Nov 16, 2009 | 06:21 PM
EvoRob22's Avatar
ACT clutches are known to have this problem. New clutch should fix it.
Old Nov 16, 2009 | 07:09 PM
Sideck's Avatar
i dont want exedy because i want a push style... and exedy with push style is overpriced.....
im going to get a competition clutch....
im pushing 500+
Old Nov 17, 2009 | 06:20 AM
SeeCoryRun's Avatar
i have this exact issue, but im on stock clutch at 48k miles. time for a new clutch for me?
Old Nov 17, 2009 | 10:20 AM
Sideck's Avatar
if you have stock clutch... i think you need a new clutch..
Old Nov 17, 2009 | 11:31 AM
SeeCoryRun's Avatar
well, ive looked arround a bit. when i switched to amsoil, i used the gl5. i was told that it was ok, but now im finding here on evom that you shouldnt use the gl5, only gl4. so imma switch to gl4 and see how it does. i do have a feeling a new clutch is not too far down the road :/
