Possible to drill/tap thermostat housing?
Old Nov 21, 2009 | 01:23 AM
F0RSAKEN's Avatar
My FD's thermostat housing had a spot that was thick enough and in a non-critical location to be drilled and tapped for a 1/8NPT temp probe. Is there a spot on the Evo's that can be drilled and tapped for a temp probe?
Old Nov 21, 2009 | 02:42 PM
F0RSAKEN's Avatar
Anyone? I don't mind being the first to try, if it hasn't been attempted before.
Old Nov 21, 2009 | 02:57 PM
Force-Fed Performance's Avatar
yes you can drill and tap it for a temp sensor, or you can get the sandwich fitting where you cut the upper rad hose and slamp in between it.
