Front diff went out...possibly tc as well?
Old Nov 22, 2009 | 09:13 PM
04EBevo's Avatar
Well after some hard launching my car started to bind up in turns as well as clunk when I turned the vehicle. These are the signs of a blown differential. My car has never had the death whine but has had a little whine when down-shifting into first gear and only first gear. Now the noise is slightly louder but I still have no high speed whine. I am going to be getting a new front diff but I was wondering If you guys think my tc is going bad too. For obvious reasons I am not driving the car but want to get back into the seat asap as driving a focus is not quite as enjoyable. Thanks in advance!
Andrew
Old Nov 22, 2009 | 09:18 PM
06ravenmr's Avatar
the clunking is probably ur spyder gears... the whining when shifting into first and second is normal.. if ur front diff is bad i have a front lsd out of a 9mr with only 2200 miles on it.. let me know and good luck. i just blew my tcase
Old Nov 22, 2009 | 09:36 PM
4RETECH's Avatar
Front axles are okay??
Old Nov 22, 2009 | 09:40 PM
04EBevo's Avatar
Thanks man I hope we both get running soon! And the axles appear fine its just there is this smelly yellow fluid on my tc around where the left cv joint enters into the tc.
Old Nov 26, 2009 | 10:36 PM
gregrego's Avatar
I blew my tc in the fall. Since your car's an 04, and you've launched it, and have some power adders, its a good bet the case is weak, and causing your problems. Send it to shep, and get the stage 2. It's pricey if you want the MR LSD, but I recommend it, the engagement is so nice. Shep's work is incredible, and the turn around time for me was 2 weeks and I live in Canada.
Old Nov 26, 2009 | 10:39 PM
xspsi4's Avatar
If you just blew the front diff then it is an easy fix as the t-case dosen't even have to come down.
I have a low mile front diff if you need 65.00 to get you back on the road.
Old Nov 26, 2009 | 10:43 PM
gregrego's Avatar
The front differential is housed where? in the transmission?
Old Nov 26, 2009 | 10:44 PM
javicracer's Avatar
what diff between a normal lsd and the mr lsd. I know that they are the same.
Old Nov 26, 2009 | 10:52 PM
gregrego's Avatar
I was told the non MR VIII were open diff, and the 8 mr was a LSD.
Old Nov 26, 2009 | 10:58 PM
EvoFredo's Avatar
the diff is inside the t case. i blew my diff up before and just opt for the basic rebuild by shep. came back great. wish i had the money for the IX front lsd.
the mitsu lsd is the same the RS IX or MR. it is the upgrade for the evo VIII. but you can go for an aftermarket one for more cash. and those are usually stronger hope that helps
Old Nov 26, 2009 | 11:02 PM
xRoguex's Avatar
ALL 05+ have an LSD.. rs, gsr and MR
03-04 are open unless its an RS the 04RS is a LSD
Old Nov 27, 2009 | 11:12 AM
gregrego's Avatar
Ah! Clarity, thanks guys. I was pretty sure the center diff was also the controlling device for the front axles. That's how it mechanically looked when I put the car back together.
Old Dec 1, 2009 | 04:41 PM
04EBevo's Avatar
Well we drained my tcase fluid and it was perfect. lifted the car and started turning the wheels and stuff and it turns ut the binding can be felt if you res your hand on my tranny. Andd the noise is within my tranny. The noise when i still have the clutch engaged but put it into first are my synchros. Probably my center diff. Anyways drained the trans fluid and it has tons of metal in it and is also metallic.
Old Dec 1, 2009 | 05:05 PM
[I.R.A.]_FBi's Avatar
thats bad :|
Old Dec 5, 2009 | 09:42 PM
04EBevo's Avatar
Well boxed everything today. When I was tilting the tc to gett the last drops of oil what looked to be chunks of spider gears came out.....
