Clutch or something BROKE!!!
Old Nov 28, 2009 | 01:20 AM
  #31
mitsuevodriver's Avatar
Wait, sorry I came on to this late but the bolt on the left side fell. I just took the right screw off. Sorry. But really
Old Nov 28, 2009 | 01:26 AM
  #32
javicracer's Avatar
Where r you located?!?!?
Old Nov 28, 2009 | 01:40 AM
  #33
In Cali.
Old Nov 28, 2009 | 07:36 AM
  #34
crewdawg130's Avatar
replase the rod and the missing bolt, bro
Old Nov 28, 2009 | 05:09 PM
  #35
barneyb's Avatar
The thing that is loose is the slave cylinder. It has to be bolted down to work. You step on the clutch pedal, fluid is pushed to the slave cylinder forcing the rod out. The rod pushes the throw-out arm, disengaging the clutch.
So, get some replacement metric bolts. You should probably check inside the boot to make sure the piston inside the slave cylinder is still inside the slave cylinder. No stepping on the clutch pedal until this is reassembled. Also, in one picture it looks like the end of the throw-out arm is broken. Hopefully, this is an optical illusion but if not you need to replace the arm.
Old Nov 28, 2009 | 05:55 PM
  #36
buchnerj's Avatar
This information would have been helpful when explaining the picture.
Barneyb is right, replace the bolts and see if it works. If the fork is broken you must replace the fork assembly.
Old Nov 28, 2009 | 06:10 PM
  #37
The arm is not broken. you can clearly see the cup on top.
Old Nov 28, 2009 | 06:17 PM
  #38
Joshs EVO's Avatar
Originally Posted by javicracer
i dont think is possible bent that rod!
The rod look like that if the cylinder slave is not bolt in the tranny!
Trust me its possible. I did it Sept. The rod bent at say a 25 degree angle.
Old Nov 28, 2009 | 06:21 PM
  #39
evofabulous's Avatar
looks broke to me. the end of the rod is supposed to be rounded off
Old Nov 28, 2009 | 06:36 PM
  #40
it is round, look at the first pic closely. The other 3 pics are blury or he movrd when he took it.
Old Nov 28, 2009 | 11:31 PM
  #41
Sorry but my gf took the picture. I was holding the light. lol! But Which one is the rod? Is it the little metal stick thats inside the rubber? Should i just buy the slave cylinder then?So wait. The metal piece(which i think is the rod?) suppose to bend like that wihle it goes into that other metal piece. Sorry its confusing but i need to know.
Old Nov 29, 2009 | 07:33 AM
  #42
morning bump. Help!! HEHEH
Old Nov 29, 2009 | 07:43 AM
  #43
whitegalant's Avatar
The arm looks fine. It looks to me as well as many others like the push rod that comes out of the slave cylinder is bent.( the slave cylinder is the piece that is held on with the two bolts)
Old Nov 29, 2009 | 07:52 AM
  #44
FutureNoob's Avatar
bump
Old Nov 29, 2009 | 08:12 AM
  #45
So is the rod suppose to be going straight into that black metal piece? Or does it bend alittle when it sits into that black metal piece. This is what i meant. Click the picture one time to zoom in if you cant read what it says. Thanks
http://i830.photobucket.com/albums/z...tsuproblem.jpg
