hks t04z vs pt6262
Old Nov 29, 2009 | 10:51 AM
shovi45's Avatar
hks t04z vs pt6262
Hi i just finshed up my build
it is a tomei 2.2 stroker with motec m800 with every thing from cams valvetrain etc
i have a brand new hks t04z and i want to know wich turbo will preform better on the 1/4 and max whp the hks or the pt6262
i have a fullrace t4 manifold
i waa reading only great thing on this 6262 and im thinking to sell my hks and by the 6262
Thanks
Old Nov 29, 2009 | 10:53 AM
dsmjeffro's Avatar
6262!!!!!!!
Old Nov 29, 2009 | 02:34 PM
ScorpionT's Avatar
The 6262 will walk all over a T04Z. The billet 6765 which is almost identical in size to a T04Z will perform even better than a 6262 on the track.
Old Nov 29, 2009 | 02:51 PM
zedevo's Avatar
6262 > T04Z ... If u want better of both of them go for the HTA86 ...
Good Luck ...
Old Nov 29, 2009 | 02:54 PM
LOVEBOOOST's Avatar
man, thats a no brainer. The 6262 all day long destroys the hks!! Also the hks is alot more expensive!!!
Old Nov 29, 2009 | 04:17 PM
shovi45's Avatar
Thank you guys for the answers
is it possible to get the 6262 or the 6765 in a T4 divided housing?
and how the t4 housing will preform in meanning of hp until 9500rpm for both turbos?
Thanks again
Old Nov 29, 2009 | 04:29 PM
LOVEBOOOST's Avatar
Thanks again
U should probably pm mike at awd motorsports and let him talk with u about that!!!
Old Dec 17, 2009 | 05:40 PM
R/TErnie's Avatar
I've seen an actual dyno plot of a t04z vs a 6262 on a back to back comparison that was literally identical in spool and power.
It was on an Evo... literally NO difference. You'd think it was the same turbo just maybe a little tweak on the ignition timing.
Old Dec 17, 2009 | 09:49 PM
JohnBradley's Avatar
Eric, was it this one perhaps?
Lol
Old Dec 17, 2009 | 09:52 PM
R/TErnie's Avatar
It twas! Thanks Aaron The Total Provider... JB
Old Dec 17, 2009 | 09:54 PM
Honestly, some of the difference probably is timing. Both cars are on AEMs, one is a 9:1 motor on Q16 the other is an 11:1 E98 motor. Both are running the same boost to make this power. I would think the sacrifice of 20 ft lbs to make 5 more whp and save a couple hundred dollars is a good trade...but what do I know
Old Dec 18, 2009 | 04:04 AM
crcain's Avatar
Don't discount the T04Z! Norris use some variety of the T04Z with Shearer headers and I think Simon knows a little about Evo's and powerband.
Old Dec 18, 2009 | 07:39 AM
giangi's Avatar
Thanks again
Lookin for a 6765 with divided t4 exhaust housing i've found this, but no feedbacks about how it works.....
http://realstreetperformance.com/sto...00hp-1311.html
Old Dec 18, 2009 | 07:57 AM
RealStreet's Avatar
We have done divided set ups for a few customers, I'm not sure if any of them have been for an EVO, we have done a few for Hondas and for Supras. Direct back-to-back feedback will be tough to come across as most people do not buy the undivided housing, then put on the divided housing to see the difference, much less try two manifolds.
We can build the 6262 in divded T4 .58, .70 and .84 A/R, and the 6765 (or 6265) in a whole host of different sizes.
In regards to the T04Z vs the 6262, the 6262 is going to come online a bit quicker all else equal. It uses a 71mm turbine as opposed to the larger P-Trim sized T04Z wheel (I believe it uses a 75mm turbine if memory serves).
I wouldn't consider the 6262 a larger power unit across the board, however it does compare amazingly well for the size of the compressor wheel. Another thing that needs to be taken into account is where the turbo will be operated. In an E98 case for example, especially with big cams and a small turbine housing as many people select, you will start to run into the flow restriction of the smaller turbine wheel which will lead to a precipitous VE fall off where high rpm torque and power will suffer.
In this scenario, at least the larger turbine housing would be recommended - but possibly also a move to the 6265 as we recommend for many Supra customers. It will be a bit slower to come up but it keeps the exhaust pressure more in check when you're using all of the compressor wheel, but again all applications are different of course and decisions like this are made simple with the addition of an exhaust pressure sensor so you really know what your pressure ratio looks like.
Regards,
Mark Conte
Old Dec 18, 2009 | 09:14 AM
The 6262 makes good power for the difference in inducer size yes, but it makes the same overall and spools the same. We have over 40 pulls on the T04Z car vs the 190 or so on the 11:1 car and I can tell you from firsthand experience that VIII to VIII with S2s they are pretty much identical at 36 psi.
