Super Rich issue, help please
Old Dec 15, 2009 | 02:32 PM
Appauldd's Avatar
Remember that air will always travel the path of least resistance. Any air that is not metered by the MAF will not be used in calcualting the AFR for the car. Since the hole is the path of least resistance the air bypasses the MAF. Thus the MAF reads less air than is actually there. The O2 sensor sends it's reading to the ECU and an adjustment is made to compensate for the o2 conditon. The problem is that the car has no idea how much air is comeing in and throws fuel at it to try to stay running.
This is why it is essential to regualarly check for leaks in the system. You might even consider doing a vacuum leak test as well.
I hope that kind of makes sense.
Old Dec 15, 2009 | 04:57 PM
Raceghost's Avatar
The hole is after the MAF though...
Correct me if I am wrong, tHe MAF is connected to the air filter. Air runs from the air filter, through the MAF, then runs through the turbo, and is sent through the intercooler. This hole is after the intercooler, theoretically it should have already been metered... So air is leaking out, and less air is going into the throttle body?
Old Dec 15, 2009 | 05:32 PM
Appauldd's Avatar
That is just the point....since the air is coming in through the hole rather than through the MAF.
Think about this....the filter is restrictive....the turbo is restrictive.....the intercooler is restrictive. Thus, the incoming air tries to find the way in that is the least restrictive. That hole is the least restrictive.
As the car is at idle it is under vacuum. The airwon't blow out the hole, rather it will be sucked in it.
Old Dec 16, 2009 | 10:58 AM
Raceghost's Avatar
Thanks appauld, got it now...lol.
Old Dec 16, 2009 | 04:10 PM
lillev23's Avatar
will this also cauce the car too run rich in boost because air that is passing the maf is blowing out of the hole?
Old Dec 17, 2009 | 10:48 PM
Raceghost's Avatar
Thanks everyone for the initial help. Figured I would just update the post rather than start a new thread. Seemed problem was a hole in the UICP. Still having issues though, update is in the initial post.
Thanks in advance.
Old Dec 17, 2009 | 10:52 PM
JohnBradley's Avatar
RG I have a used Green you might be interested in. PM billy@englishracing for more details
Old Dec 17, 2009 | 10:57 PM
Raceghost's Avatar
Thanks John will do. Any ideas on my new backfiring issue?
Old Dec 17, 2009 | 11:00 PM
I'll do some thinking
Evo47
Jan 3, 2017 06:43 AM
Femi
AEM EMS
23
Apr 5, 2016 11:38 AM
-Hum-
Mar 26, 2015 08:44 PM
Raceghost
Dec 17, 2009 10:55 PM
