any pro/cons Kelford Cams 280/282 Evo9
Old Dec 11, 2009 | 09:35 AM
chin0's Avatar
I was wondering if any evo IX onwers had ever used the Kelford 280/282 cams for the evo IX (with the Mivec and all) What where the pros & cons? Is there a noticeable gains with a tune on the top end and what about the low end? Also with little to no mods, is it worth it to go that big that soon? I mean I could just buy them and put them in and get a tune and then add on later, but I am not sure if it will harm the motor in any way. I want them but just not sure please give me your .02 cents i'll take any type of info!
mods: K&N open filter, TBE with a full TI catback, exedy twin HD, strai 60mm boost/EGT/oil temp. gauges, b&m short shifter and will soon get a Buschur Deluxe Intercooler with Lower intercooler piping. (other small stuff)
Thank you for your time!
Old Dec 11, 2009 | 09:36 AM
Kracka's Avatar
Make sure you get the new cores that aren't supposed to snap.
Old Dec 11, 2009 | 09:38 AM
chin0's Avatar
what do you mean the old ones are known to snap???
Old Dec 11, 2009 | 09:41 AM
Force-Fed Performance's Avatar
we have never seen any issue with them snapping andhave installed and sold a ton of them, however i wouldnt advise you to get the 280/272 setup unless you have a pretty large turbo (larger than a 35r) they have some serious lift and need some pretty beefy springs
Old Dec 11, 2009 | 09:44 AM
chin0's Avatar
have you seen any type of problems with that setup with little to no crazy mods? (280/272)
amui07's Avatar
I thought the snapping was limited to a specific batch of the Kelford 272 for the evo IX
Old Dec 11, 2009 | 09:46 AM
chin0's Avatar
Old Dec 11, 2009 | 09:57 AM
chin0's Avatar
So should I go 280/272 then? But is it worth it if I am mainly stock?
Old Dec 11, 2009 | 10:10 AM
b16a95eg's Avatar
I have 272's in my 8. And honestly I couldnt be happier, I'm sure 272's will be enough, unless you have some crazy build in mind? But for me the 272's are perfect for the street. You wont be disappointed
Old Dec 11, 2009 | 10:15 AM
we have used just about every cam there is. We really like GSC, and kelfords. most of our customer cars are Kelford unless they request GSC. the 272 as we see it is BY FAR the best cam across the powerband on a stock to 61mm turbo. I would suggest going with the 272 if you are mostly stock. Let me know if i can get you a set
Justin
Old Dec 11, 2009 | 10:18 AM
chin0's Avatar
Im just worried because of the Mivec and all. also ForceFed can you pm me some prices on the cams for an '06 Evo IX please.
Old Dec 11, 2009 | 10:27 AM
yes sir, on the way
Old Dec 11, 2009 | 10:33 AM
SmurfZilla's Avatar
The only other cam I have seen pretty impressive power with from stock to GT35R's is the FP4R (GSC S2 gets honorable mention)
Old Dec 11, 2009 | 10:36 AM
Yes sir, They are amazing cams too and we use them also upon request.
Old Dec 11, 2009 | 10:38 AM
Kracka's Avatar
My favorite MIVEC cams are those made by FP, the 4R and 5R.
