Ceramic ball or metal ball
I recently purchased a Hallman Pro Rx with the additional metal ball. I'm currently tuned at 26lbs of boost. Which ball should I use? I'm currently running on the ceramic ball wi the heavy spring. When I called Hallman they told me that for my application I should run the metal ball. Which should I use?
Hmmm seems odd, I do know that with a metal ball MBC that I ended up coating everything inside with anti-sieze to avoid corrosion issues over time. This is on another brand MBC but the same concept still applies. You would think the ceramic ball MBC would be superior in every way though.
I'm running the heavy spring with the ceramic ball right now at 26psi till redline.
When you called hallman You spoke with Julie and she knows what she is talking about.
-Em
recommended the metal ball. Maybe I'm giving too much credit to the receptionist that answered the phone when I called.
