Exhaust Size vs HP & TQ
Old Dec 24, 2009 | 10:19 AM
  #91
David Buschur's Avatar
Oh, porting of the turbine housing, the T3 and T4 housings don't have much area for improvement when it comes to porting like the stock stuff does.
Old Dec 24, 2009 | 12:24 PM
  #92
R/TErnie's Avatar
Originally Posted by davidbuschur
Damn it, I had a nice long response typed up a lost it......this one is going to be a lot shorter.
evovin, side exit exhausts are done for ease of fabrication, weight, straightness and we have done them as far back as the mid-90's for safety. Blow a head gasket or have something happen to an engine and the water/oil get shot out the side of the car rather than under it where you have to drive through it.
R/T, I know you know this, I am just typing. While a 1:1 ratio of boost vs back pressure sounds great and is great for top end power it sucks to drive it. The HTA86 in the single scroll .82 housing has a good mix of response and top end. I wish I had the datalogs from the testing but I want to say at 40 psi of boost somewhere around 6,000 rpm the back pressure gets to be higher than the boost pressure. That is just a best memory of what we saw. Since then the header design has been changed, the 02 housing and the turbine housing. The real Garrett GT housing is absolutely the best T3 housing I have tested, our FF kit uses a custom machined housing with a 3" V band outlet and out 02 housing on that kit is 3". The turbine wheel though is only about 2.5" on the exducer.
yeah it's too bad the GT housing wasn't more compact. Either that or I need to take off my A/C
Old Dec 24, 2009 | 05:55 PM
  #93
Did you miss the part about the custom machined GT housing It's compact enough now.
Old Dec 24, 2009 | 06:09 PM
  #94
R/TErnie's Avatar
pictars please!
I was looking at the head flange, turbine inlet flange, and the precision 6262 T3 .82 AR Housing tonight...
The SLS CNC'd head flange has recessed ports in the head for 1.5" sch10 tubes to sit in (not really necessary) and due to this the tube comes very close to the bolt holes (on top) and once you lay a fatty bead on it... your fasteners will be clamping on the weld and not a flat flange surface!!!! So I'm looking for a new head flange... perferrably one that is 2D and is not contoured like the SLS unit.
The CNC'd turbine T3 inlet flange appears to be drawn off of a smaller T3 opening than the std t3 housings. I'll either have to hand port this out to the right size... or just buy a 1/2" thick RIGHT SIZE T3 flange.
Upon looking at my T3 turbine housing from Precision (looks like a 4 Bolt std t3 housing that was lathed down to make a 2.5" v-band outlet) Looks uber small and will require a 2.5"->3" transition...which takes up precious lateral space while serving NO good purpose! I was considering making a fixture to bolt my housing to (6 bolts that bolt from the center section). Bolt the housing to a big block of 7075 that I have sitting around, and mill the discharge down as far as possible. By my eye-crometer I think I'll be able to get up to 3/8" more lateral room by machining the housing in further. I would then weld a 3" v-band flange onto the turbine discharge and then port/blend the turbine housing to the discharge.
By my estimates I'll save at least 1/2" by not using a 2.5" to 3" transition and then I'll save another 3/8" by machining the housing. This gives me a whopping 7/8"!!!!! to fit my fatty large CLR 3" tube through.
What's your take on my idea Dave? I'll have to hit up some people for advice on TIG welding to a cast iron housing. (Preheat + Nickle Rod using a Mild Steel v-band flange)
Old Dec 25, 2009 | 09:59 AM
  #95
We have a 3/8" thick SS header flange we use with the schedule 10 tubing. I buy my T3 collector from Shearer for any custom headers we do, because his are just to nice to mess with trying to make on our own.
The 6262 housing........sorry you are screwed using ours. I thought you had a GT35r, that housing we have the Garrett T3 GT housing machined specially for our FF kits and the 3" V'band end up nearly flush with the side of the turbine housing. VERY compact. We had to machine them so a full 3" 02 housing in Vband would fit our FF kit.
Old Dec 25, 2009 | 12:25 PM
  #96
R/TErnie's Avatar
Nice work dave. If I ever go to a 35r variant I'll let you know. Can you PM me a price on the head flange?
I make my collectors at a lower angle and subsequently longer than most people do for the Evo... so I'll just end up making mine.
Old Dec 27, 2009 | 08:11 PM
  #97
3gEclipseTurbo's Avatar
would exhuast wrap really help the flow and gain any hp or tq? A lot of people wrap the header and dp, would wraping the whole exhuast be better than just the dp?
Old Dec 27, 2009 | 08:22 PM
  #98
Appauldd's Avatar
The wrap helps to hold heat in the exhaust. Hot air travels faster than cold, thus, in theory, the wrap should improve exhaust flow.
In addition, the wrap will greatly reduce under hood temps.
I have mine wrapped from the O2 housing out to the resonator. After the resonator is not wrapped.
I also helped to quied the tone in the car.
Old Dec 27, 2009 | 09:42 PM
  #99
03whitegsr's Avatar
It's pretty interesting to look at pressure drops relative to air temperature.
As velocity goes up, frictional losses usually do too...
Good heat management has a lot of benefits over changing air velocities though.
Old Dec 27, 2009 | 09:53 PM
  #100
Appauldd's Avatar
Heat has a direct relationship with pressure within a given volume. Pressure can be increased which will cause an increase in heat and vice versa.
If air is heated and released it will move at a faster rate than cold air.
In the case of the exhaust, controlling the heat is essential to keeping volumetric flow maximized. If the exhaust is allowed to cool too quickly some of the scavenging effect could be lost.
Frictional forces of smooth walled pipe and exhaust gasses are, in my opinion, very minimal when used to determine velocity. Bends will affect the velocity more than the frictional forces of the pipe.
AAAHHHHH Fluid Dynamics....I hated that class.
Old Dec 27, 2009 | 09:58 PM
  #101
l2r99gst's Avatar
To maximize turbine efficiency, you want the exhaust pre-turbine as hot as possible (highest pressure) and the exhaust post-turbine as low a pressure as possible (low temperature).
So, ideally you do not want to wrap anything post-turbine, such as the O2 housing or downpipe. Most ppl do it for a couple of other reasons, though, such as quieting down the exhaust note a touch and/or to control heat to nearby components.
Old Dec 27, 2009 | 10:33 PM
  #102
Appauldd's Avatar
But if there is too quickly of a pressure drop you create turbulence in the flow which hinders flow considerably. Thus my suggestion earlier about an increasing diameter pipe (like a cone) from the turbo out. Then you can decerease pressure and minimize turbulence while still keeping the flow as fast as possible.
Wraping the DP isn't a bad thing by any means. They run so close to the oil pan that anything that can be done to reduce radiant heat getting to the oil is good.
Old Dec 27, 2009 | 11:59 PM
  #103
03whitegsr's Avatar
An exhaust isn't a closed system. Increasing the heat does not increase the pressure, since it is an open system the air at higher temperature just expands to fill a larger volume.
If air is heated and released at the same pressure as cold air, frictional losses will dictate mass flow rate. Because the air is more "excited" at higher temps, you'll find that frictional losses increase as temperatures increase.
Frictional forces aren't about calculating velocity. That's pretty much left to mass flow rate and fluid density in a system like an exhaust, mass balance. Frictional loses will create pressure drops though and, at least from theory, produce rather large losses in exhaust systems.
Agreed and as stated above, losses in bends are huge and keeping heat out of the oil is the #1 reason I have a wrapped downpipe.
Old Dec 28, 2009 | 07:13 AM
  #104
Appauldd's Avatar
Thanks for the lesson.....It has been years since I had those classes. It is amazing what you lose if you don't use.
I too wrapped my DP and out to the resonator for keeping heat out of the oil and out of the cab. I had to remove my cat heat shield because it rattled like crazy.
Old Dec 28, 2009 | 04:53 PM
  #105
I don't like wrapping anything after the turbine housing either. We use a shield on the oil pan that we started using originally when we built the BR330 and BR350 Edition EVO's. It's a simple self adhesive heat shield that we stick on the oil pans over the downpipe. I have one on my RS. I have used ceramic coating on the downpipe.
