Steering shaft question
Old Dec 17, 2009 | 09:56 AM
Werd's Avatar
Is it possible to pull out the steering shaft that splines up with the steering rack without dropping the cradle?
Old Dec 17, 2009 | 10:11 AM
MR Turco's Avatar
yes. There is an access panel under the dash that will allow you to remove the 1 10 or 12mm bolt and you can wiggle the steering shaft connection off the rack.
Old Dec 17, 2009 | 06:46 PM
Werd's Avatar
Alright cool, i know the access point your talking about, just wasn't sure if there was enough play to get it out. Thanks.
