how much hp can stock evo8 trans hold
Old Dec 23, 2009 | 04:13 PM
sktng22's Avatar
Anyone know how much hp the stock 5 speed trans can hold?
Old Dec 23, 2009 | 04:17 PM
dahuii77's Avatar
500whp thats the 5sp 03 evo 8.............
Old Dec 23, 2009 | 04:35 PM
zedevo's Avatar
700hp .. easily
Old Dec 23, 2009 | 04:40 PM
holiday63's Avatar
im at 600whp on a stock trans and its still crispy.
tcase is your definative weak point
Old Dec 23, 2009 | 04:42 PM
Boltz.'s Avatar
FCOTM Winner
The funny thing with the evo's is you never really hear this question being asked, mostly because they are so strong. You might break a part inside during a launch, but you'll never hear about a broken bell housing like in the FWD SR20's... I'd say whoever is asking the question won't make enough power to break it so don't worry about it.
Old Dec 23, 2009 | 05:05 PM
zedevo's Avatar
Tcase is your definative weak point
+ 1 ...
Old Dec 23, 2009 | 07:10 PM
JohnBradley's Avatar
all way wrong. 1117whp
the question is more how long does it last when you F up on the shift.
Old Dec 23, 2009 | 07:16 PM
EmeryatSTM's Avatar
I think the stock trannys will for the most part stay together with what ever you through at them. The part we see fail all the time is the synchros which I blame on the clutches used.
-Em
Old Dec 23, 2009 | 07:34 PM
Kracka's Avatar
I agree with JB and Emery, it really comes down to the driver and if s/he has the clutch adjusted properly.
Old Dec 23, 2009 | 07:52 PM
stryfetew's Avatar
05+ have the stronger transfer cases I''ll probably never go over 500hp myself.. I seen a guy grenade a 05 trans but he was quite dumb when it come to racing. I'm thinking he was in the 470ish range.
Old Dec 23, 2009 | 09:06 PM
sktng22's Avatar
ok well how much can the stock tcase hold?? haha
Old Dec 23, 2009 | 09:16 PM
Teal2nnr's Avatar
Ok so if these 5spds are so strong, then why would people run shep tranny's? (not being an *** simply asking)
I thought they weren't reliable past 420whp ish..... but i don't own a drag car...so....
Old Dec 23, 2009 | 09:25 PM
holiday63's Avatar
That's another question with no concise answer dude. I mean an Evo tcase will function properly under normal driving conditions even at excessively high hp. Throw in a hard launch or two however and it's definately toast.
I mean there's guys on this forum with stock evos that are eventually breaking tcases due to launching and aggressive driving. There's no magic number of hp where **** will just stop working. I'd say if u plan on drag racing or doing a lot of auto-x a new diff is probably in your future otherwise use your best judgement
Old Dec 23, 2009 | 09:31 PM
FTY Motorsports's Avatar
it depends on a few things how you drive your car mainly if you drag race it and launch hard then ur gonna kill it much faster if its road racing your gonna last a while. shep trannies are great upgrades because you get more insurance and the syncros are way better. especially the 5th gear syncro issue
Old Dec 23, 2009 | 09:47 PM
holiday63's Avatar
A 5speed won't just let go at 420 hp but there's less room for error at that point when shifting at high rpm and high hp. If your shifting is smooth and on point you have less to worry about, where as if you are bending shift linkages and losing dog teeth due to sloppy work you may have issues
When I had shep put a wavetrac diff in my tcase I asked him at what point I should worry about the trans. He basically said the tranny won't break... It just may not shift too good after a season of hard wear
