Boost gauge concern - help?
Old Jan 14, 2010 | 09:33 AM
NelloMorto's Avatar
Hey Guys,
I just recently installed a Stewart Warner 30 Hg - 25 Psi boost gauge in my 2004 Evo I just picked up back in November and I'm noticing that it's only hitting about 16 or maybe 17psi at full boost. Searching around I read that stock boost was roughly around 19psi then declines to around 16psi at higher rpms. I'm just throwing this out there but could this be the result of a leak somewhere in the vacuum line connections? I made sure all the zip ties were tight but of course I haven't checked for leaks yet because I haven't had a chance to bring a buddy with me for a ride to place his hand under the dash where the nylon tubing joins some rubber vacuum tubing.
Thanks for any suggestions!
Old Jan 14, 2010 | 09:39 AM
TeStUdO's Avatar
Sounds like you're hitting wastegate boost. Make sure you have the factory boost solenoid hooked up.
