Rear diff and t-case fluid
Old Feb 16, 2010 | 06:46 AM
hashaam81's Avatar
Stick to OEM fluids.
Old Feb 16, 2010 | 01:28 PM
jid2's Avatar
Can anyone talk to the difference between using heavy duty shockproof vs normal redline 75W 90 gear oil.
I'm about to change out the fluids for this year. I've used castrol 75W 90 gear oil in the past, but looking to go redline this year.
Old Feb 18, 2010 | 06:16 PM
brokenRS's Avatar
Whats the price on the diaqueen? I went to my local mits dealer and it was 126 something.
Old Feb 18, 2010 | 06:34 PM
kyoo's Avatar
what's wrong with using amsoil severe gear
Old Feb 18, 2010 | 11:02 PM
1SloEvoNoob's Avatar
bout to go get t case fluid for my 30k...do i see 126.....
Old Feb 19, 2010 | 10:09 AM
EVOlute GSR's Avatar
Seems like suggestions are going all over the place. After reading this thread, one wouldn't know exactly who to go to. BUT I do understand that everyone is running either:
-Diaqueen OEM,
-Redline 75-90
-Redline Heavy ShockProof in TC & Rear diff
-AMS oil 75-90 severe gear oil
Minority:
-Royal purple max gear.
Most say stick to stock Diaqueen (very expensive) for stockish HP and Readline shockproof for either stock or high hp.
As I am at the 30k mile mark, I am probably leaning with Redline heavy shockproof for both transfer case and rear diff. Any last suggestions that would help the crowd?
Old Feb 19, 2010 | 12:01 PM
apagan01's Avatar
nohing,, hundreds of customers using it here on this community
Old Feb 19, 2010 | 12:05 PM
tim85851's Avatar
stick with diaqueen...
for tranny fluid you can go with whatever...lol
Old Feb 19, 2010 | 12:21 PM
tim85851's Avatar
thats if you buy the full gallon...
they allow you to bring empty containers and buy it by the quart...it should be around 20 or so for a quart...its pricey but you only need i think 2 quarts...
i just went to walmart and bought a cheap 1gallon container and had mitsu fill it up a little more than half way...
hope this helps.
Old Feb 19, 2010 | 12:22 PM
tim85851's Avatar
i do however want to try running amsoil in my tranny...what should i get mr amsoil man?!
Old Feb 19, 2010 | 12:34 PM
apagan01's Avatar
MTG GL4 75W90, fully synthetic heavy load gear lube.
Old Mar 3, 2010 | 10:11 PM
For an evo 8 transmission fluid change, is it better to get Redline MTL GL-4 or 75w 90 GL-5?
Please input your advice.
Old Mar 3, 2010 | 10:39 PM
DaveK's Avatar
I run redline heavy shockproof in the TC (wavetrac diff) and rear diff (carbonetics 1.5) and lightweight shockproof in the transmission (shep street/strip). This is pretty much a race only car that does hillclimbs and track days. My IX makes north of 600whp when the boost is turned up.
Dave
Old Mar 3, 2010 | 11:04 PM
Bigdawgmotors's Avatar
Dave
Do you have to add any lsd additive in the rear diff? i bought redline fluids for my car but havent done the rear diff yet cause im not sure if u need an additive for lsd.
Old Mar 3, 2010 | 11:12 PM
DaveK's Avatar
I bought a little bottle of the additive a while back but never used it. On my car I want the lockup to be very aggressive since I'm racing on loose surfaces like dirt and ice. I *think* the additive can be used to lower the viscous nature of the fluid in there to 'tune' or soften the diff a bit...but don't quote me on that.
Dave
