Question about injector seals and o rings
I picked mine from local mitsu-part dealer. they are called O-rings - you can probably re-use your old ones, depends on what condition - if you see any cracks, just buy new ones otherwise it will leak. Im also running prec. 880
just order the seal kit from FIC - it works with those injectors. I ran 880's for a while and used the FIC seal kit, imo it is much better than what PTE gives you.
http://www.fuelinjectorclinic.com/cg...ey=SLK-125-6X4
Just making sure before I order this for my Precission 880s. This comes with the o-rings and seals right?
Anyone? Bueller?
Im about to install my PTE 680's, they didnt come with seals either. I was thinking of re-using the OEM seals but not sure of the condition. Might as well order something to use and be done with it.
The FIC seals mentioned earlier, they are compatable with all PTE injectors correct?
Bren
Bren
boosted91t
23
Apr 2, 2013 07:23 AM
boosted91t
Sep 26, 2012 04:44 PM
boosted91t
Jul 9, 2012 07:43 AM
boosted91t
Jan 3, 2012 12:57 PM
