o2 housing problem, please help...
Old Feb 7, 2010 | 09:28 PM
EvolutinIX's Avatar
It took the whole weekend but I got my maperformance o2 housing installed. Now it looks like it may be leaking from the bolt hole closest to the radiator, its tight, thought it may be wd40 but its been smoking for like twenty minutes. Any ideas would really help me out, thanks
Old Feb 7, 2010 | 09:31 PM
Mike.p's Avatar
my car smoked for a while from the dw40 but then eventually burned all off......... just keep driving and check it out in a day or so... btw did u get the external dump?? if so how do you like it
Old Feb 7, 2010 | 09:46 PM
EvolutinIX's Avatar
Yeah I did, honestly I don't think people give this mod enough credit. I have only drove it once and I even turned the boost down to 19 psi, but it pulls much harder and a bit quicker and sounds great. Getting started tuning so ill let you guys know if it actually makes more power or not. So you think the smoke is wd40 not exhaust?
Old Feb 7, 2010 | 09:56 PM
Mike.p's Avatar
yeah ill bet u it wd... just drive it and it should go away within a day or 2....... were u tuned with a standard aftermarket o2?? and what o2? and will u be getting retuned with just this mod? id like to see the hp diff between the 2
Old Feb 7, 2010 | 10:34 PM
jmelocik's Avatar
DId you use regular anti-seize on the threads? When I put the new exhaust on mine a few years ago it smoked for a while because I put to much on. Take it for a decent drive and then come back and check it out.
Josh
Old Feb 8, 2010 | 01:26 AM
EvolutinIX's Avatar
I used copper high heat anti seize but I can only hope I used enough, how long is too long if it keeps up?
Old Feb 8, 2010 | 01:30 AM
EvolutinIX's Avatar
I used copper high heat anti seize, hope I used enough. How long is too long if it keeps acting up??
Old Feb 8, 2010 | 01:53 AM
jmelocik's Avatar
I took mine for a 30 minute drive after words cycling it hot and hotter. When I got back it still has slight wisps of smoke coming off of it.
Josh
Old Feb 8, 2010 | 10:27 AM
ChrisCarey's Avatar
There is usually some burn off that can last for a while, do you hear any ticking coming from that area? I can't say we've ever had a problem with one of these units not sealing properly...
Old Feb 8, 2010 | 11:06 AM
Kevin.'s Avatar
Do you have your under tray on?
Old Feb 8, 2010 | 11:50 AM
EvolutinIX's Avatar
No under tray on, no ticking just the loud fuel injectors. I made sure to do a star pattern when tightening the housing, guess time will tell...
Old Feb 8, 2010 | 12:10 PM
evokid511's Avatar
when i did my o2 housing i forgot to put a bolt back on the block wher the factory o2 housing bolted to and it was leaking oil onto the dp so that caused maddddd smoke...
