idle problem
Old Feb 15, 2010 | 03:41 PM
shangai's Avatar
idle problem
i have a 2003 evo and when i im parked and i acelerate the car, when it drops, the iddle go to low and the afr on my wide band goes to 8. for a few seconds,almost turning off the engine and it compensates and then i goes back in a perfect iddle and the mix on 14 as it should be. what can itr be?
Old Feb 15, 2010 | 04:32 PM
BLK_EvIL's Avatar
what bov are you useing and is it recirculated
Old Feb 15, 2010 | 08:57 PM
shangai's Avatar
stock evo 9 one and istalled as stock goes.. recirculated
Old Feb 17, 2010 | 08:27 PM
shangai's Avatar
no ideAS?
Old Feb 18, 2010 | 06:02 AM
shangai's Avatar
Yesterday i change my mass air meter and no luck. Today i will try a new o2 bank one from another evo, also im getting rid of the egr to see if i get lucky.
Old Feb 18, 2010 | 06:18 AM
gsrboi80's Avatar
Hard pipe intake????
Old Feb 18, 2010 | 06:23 AM
shangai's Avatar
The intake is rubber, perrin
Old Feb 18, 2010 | 06:41 AM
mt057's Avatar
Check your tune. Look at your FT and check your injector latencies.
Old Feb 18, 2010 | 07:30 AM
shangai's Avatar
TUNE IS STOCK. I REFALSH IT BACK TO STOCK. WHAT DO YOU MEAN FOR FT?
AND FOR LATENCY YOU MEAN InjPulseWidth ON THE EVOSCAN? THANKS
Old Feb 18, 2010 | 08:09 AM
Ev0ikon's Avatar
Are you using stock injectors?
Old Feb 18, 2010 | 08:51 AM
KillaItalian904's Avatar
FT = Fuel Trims you have LTFT and STFT
Long Term Fuel Trims
Short Term Fuel Trims
in evoscan your LTFT should be under +/- 5% the fuel trim is how much fuel your ecu is adding or removing in order to achieve 14.7 afr. when your stft is bouncing around like crazy the ecu attempts to stabilize the afr by making a long term change the ECUs LTFT which is what some refer to as "learning". by looking at your stft and ltft you can determine if the car is being under fueled or over fueled which could be your injector latencies or flow rate (in ecuflash) or a mechanical issue with the injectors.
Old Feb 18, 2010 | 11:08 AM
shangai's Avatar
Originally Posted by ev0ikon
are you using stock injectors?
stock injectors
Old Feb 18, 2010 | 11:16 AM
shangai's Avatar
KillaItalian904:
AT IDLE:
FuelTrim_Low FuelTrim_Mid FuelTrim_High
-3.429 -12.4496 .1008
STFT GOES FROM -4.6 TO 12
Old Feb 19, 2010 | 09:36 AM
-12.4496 is not a great fuel trim but if i am reading this correctly 12.4496 is your fuel trim MID which has nothing to do with your idle, the fuel trim mid is only for cruising. your ltft low looks good it doesn't seem like its over fueling, seems like a mechanical issue to me but thats my humble opinion
Old Feb 19, 2010 | 11:14 AM
shangai's Avatar
How about the stft? Im guessing is a bad sensor somewhere
