Help, having problem with car, thanks
Old Feb 17, 2010 | 09:13 AM
Bergen Automotive's Avatar
I have a 2006 ix Mr with the following modification,
Downpipe
Intake cone filter
Greddy Type S bov (also have stock 9 bov if need be swapping out)
HKS hi power cat-back exhaust.
the problem i am having started today, i was accelerating onto the highway and in 4th gear and when i hit 4500 rpm the car started jerking real bad. then drove fine at 3000rpm in 6th gear, when i got off the highway i accelerate again in 5th, as soon as i hit 4500rpm or higher it jerks real bad again, stops then jerks again. Would this be a bov not holding pressure? or a bigger problem, if anyone knows please help me out, i really dont want to have to spend 4 hours at mitsu to see if they can fix this under warranty. thanks
Old Feb 17, 2010 | 09:25 AM
parrothead1's Avatar
Did you ever get tuned for your mods? Also, how long have you been running on your current spark plugs. When I had my IX MR, this would also do this and the plugs were the first thing I checked.
Old Feb 17, 2010 | 09:27 AM
No tune, been running the mods for over 10,000 miles and no problem until today, and i dont know whats going on with the spark plugs but they will be replaced at 45,000 miles unless thats what is causing the jerking then i will replace them now
Old Feb 17, 2010 | 10:16 AM
EvolutinIX's Avatar
Very common problem with evos but it sounds like you have a eg and not a bov, is that correct?
Old Feb 17, 2010 | 10:22 AM
FX11's Avatar
id start small and change the plugs, then id do a boost leak test
Old Feb 17, 2010 | 11:44 AM
PROBLEM SOLVED, spark plugs were bad, one of them was completly burned and had some gunk on it, TTP engineering took care of it, A+++ for them, thanks
