Oil Leak HELP!
Old Feb 18, 2010 | 05:32 AM
karkrazy1616's Avatar
Oil Leak HELP!
Ever since i did the work on my car, which was a complete rebuild (pistons/rods/timging belt/camshafts/turbo/clutch/all the supporting mods for all of that). Now i have an only leak on the right(passenger side) of the car. It seems that it is from the Alternator down from there, Its not an insaine oil leak but i do see a few drips and the bottom of the car is half way covered. anyone got any ideas? If you could help that would be great thanks guys!
Old Feb 18, 2010 | 11:41 AM
no one?
Old Feb 18, 2010 | 11:48 AM
gsrboi80's Avatar
Could be coming from a bunch of places. They make a dye that you can add to your oil which will show under UV light allowing you to pinpoint the leak easily. Google it
Old Feb 18, 2010 | 11:57 AM
mega-z's Avatar
^ What he said. When i did my rebuild i use rtv on just about every bolt that goes into the block on that side off the motor.
Old Apr 6, 2010 | 04:53 PM
NSS's Avatar
NSS
having the same problem
Old Apr 6, 2010 | 05:56 PM
barneyb's Avatar
Anyone is welcome to correct me but I think there is the bolt on the tensioner pulley that goes into an oil gallery. Anyway, there is a bolt in that area that requires RTV on the threads.
Old Apr 6, 2010 | 06:38 PM
lemmysports2's Avatar
you are correct sir. easy to miss if you dont have a fsm, could very likely be this
