Replacing water pump
Old Feb 19, 2010 | 09:34 AM
sktng22's Avatar
Does anyone know if theres a writeup on installing a new waterpump?
Old Feb 19, 2010 | 06:31 PM
barneyb's Avatar
https://www.evolutionm.net/forums/ev...placement.html
Old Feb 22, 2010 | 04:39 PM
sktng22's Avatar
i know about that thread but it dosnt say anything about the water pump. i mean like..do u just unscrew the pump and put the new one with the gasket on? is it that straight forward or are there more things to replacing the water pump?
Old Feb 22, 2010 | 08:07 PM
gsrboi80's Avatar
Nope pretty straight forward man. Pulley off, WP bolts out, new pump and gasket in, pulley on.
Old Feb 22, 2010 | 08:08 PM
1d10t's Avatar
Getting to the pulley bolts, thats the trick
Old Jun 21, 2010 | 07:17 PM
domantas's Avatar
ive heard you got to take the timming belt of in order to take the pump out... Any way I can do this without messin with my belt, because it is pain. I just replaced the belt with the motor of the car and it was hard enough...
Old Jun 21, 2010 | 07:23 PM
jmelocik's Avatar
Take off the front right wheel and there is an access "hole" in the frame to allow you to access the pulley bolts. Just be careful and not drop the socket or bolt in the frame, it's a sonofagun to get stuff out of there.
Josh
Old Jun 21, 2010 | 07:48 PM
domantas's Avatar
so basically timing belt tensioner assembly needs to be removed in order to change the water pump? At least thats what it looks like:
http://i256.photobucket.com/albums/h...e/S4300258.jpg
Old Jun 21, 2010 | 07:52 PM
sharkm87's Avatar
looks like a balance shaft elim kit is on that pic....
with that...you dont need a balance shaft belt right?
Old Jun 22, 2010 | 11:23 AM
jmelocik's Avatar
Correct, also remember the water pump is held on with 5 bolts, one is directly behind the timing belt tensioner pulley so the timing belt pretty much has to come off or at least moved out of the way and the pulley and arm removed to get the last bolt off.
Josh
Old Nov 24, 2010 | 02:47 PM
10isace's Avatar
Thanks for putting this up. I'm doing my complete t-belt job this weekend. I was wondering if the water pump gasket needs any sealer, like gasket maker (helps seal), or is everyone just putting the gasket on. I'm happy if it doesn't need the goo.
Old Nov 24, 2010 | 08:21 PM
dude's Avatar
gasket does not require any sealer, but it's a good idea to put a real thin bead of silicon between the pump and gasket to help the gasket stick in place while you try and get the bolts thru the pump.
At least that's my experience from doing it myself. If you have another pair of hands helping that might be a non issue.
Old Nov 28, 2010 | 09:57 AM
10isace's Avatar
Thanks dude! The silicon helped big time! I just forgot to put a pan down to catch all the coolant. It takes about 1 1/2 rolls of paper towels to clean up.
Old Nov 29, 2010 | 12:42 AM
dude's Avatar
The Dude abides.
Old Sep 1, 2011 | 01:36 PM
gtpunk18's Avatar
WOW i wish i read that, i got the head on, got it all timed and the water pump gasket showed up today and went to put it on and Umm it wouldnt go. now i have take the belt tensioner off and do the pump tonite then do the belt again
