drip drop
Old Feb 20, 2010 | 09:49 AM
rartist's Avatar
Question drip drop
I just noticed a small puddle of coolant under my car, 3-4 drops behind the motor on the floor of my garage. Based on the stain its been leaking for a little while. Not too long ago I had the TB off the car, that has cooling lines and could account for a bit of the stain; but these drops looked fresh. I also saw some drops on the exhaust mount behind the tranny. One of the bolts had backed out, that's how I found it.
The line connections look secure, what else is on the firewall side of the motor that can leak coolant?
Old Feb 20, 2010 | 09:54 AM
heel2toe's Avatar
any chance your headgasket is leaking? When mine blew I found coolant sitting on the transmission hump.
Old Feb 20, 2010 | 10:07 AM
n2oiroc's Avatar
the easiest way to find it is to clean the area with degreaser and water, toss a bottle of coolant dye in the radiator, drive it a day and pull it in a dark garage and point a black light at the area. the leak will glow bright green.
Old Feb 20, 2010 | 10:17 AM
EvolutinIX's Avatar
Talking
Originally Posted by n2oiroc
the easiest way to find it is to clean p the area with degreaser and water, toss a bottle of coolant dye in the radiator, drive it a day and pull it in a dark garage and point a black light at the area. the leak will glow bright green.
Good advice this is the best way to check for leaks.
