Extrude Hone turbo parts. does it help?
http://www.atpturbo.com/mm5/merchant...egory_Code=GTH
i think the 40r housings are regular cast iron.
atp uses a sand type casting which sucks. its not as clean as garrett type castings. thats why i thought of extrude hone. but then figured to also inquire about the compressor side too
atp casts the 1.06 twinscroll 35r housings, but the 40r ones are garrett made as far as i know. oh, nevermind. i thought you had a 40r, you have the 35r. duh! i actually was going to go that route and bought the atp housing, then i got a good deal on a trade for a 40r. yeah, your kinda stuck with the atp housing. when you get a chance take a pic of the porting that was done.
that does look like crap. yikes! if extrude honing doesnt work out and if you want a better port job let me know. it doesnt even look gasket matched!
there is no gaskets. what is a down side is my manifold uses a garrett t4 divided flange mated to this atp thing. atp and garrett are both differnet flanges.
just took a pic of my turbine housing after porting. im still going to go over it with 120 grit, as its all done in 80 grit. bad pic but you can see how i got all the way down.
I had the same issue porting my IX housing, but when you get down deep, all you are really doing is smoothing the surface. You really aren't removing any material.
That's the main difference between porting and extrude hone. It removes material way down in places you can't even see and the places that you can see but just smooth out, it takes out material there too.
If I were going to send in a piece for extrude honing, I'd probably port what I could reach first before sending it off. Either that or maybe after getting it back so you don't make anything too thin before they extrude hone it. Either way, I'd plan on doing additional porting. You can get a surface just as smooth with 150 grit rolls and then the a cross-buff.
So did you get any prices back?
n2oiroc what housing is that??
