installed MBC now low boost
Installed a perrin MBC this weekend on my ix.
Ran the lines per instructions...turbo out to MBC to WG. (No it's not backwards)
After a quick test ride I started turning it in to dial up the boost. Tightened all the way I get 1 bar and it holds to redline. With the OE setup It'd flash to 1.3 bar and taper off.
I should be able to get 21 psi 1.5 bar yes.
Any suggestions?
Thanks
Shoe
Any suggestions?
Thanks
Shoe
You didn't reuse the factory rubber boost hoses did you? I imagine that the Perrin controller comes equipped with its own lines. So, did you cap off all of the unused nipples, such as the one on the factory inlet hose?
