Problem with Fidanza 3.2 Clutch
Old Mar 2, 2010 | 05:27 PM
EvolNinja's Avatar
I'm so that I had to drop my tranny the second time because the stupid ring that hold the TOB to the pressure plate came loose because after install the tranny, the fork wouldn't go back to A position.
So today, I finally got the tranny out again. I test the Fidanza pressure plate with the OEM TOB. With just one hand pull and it came right off. I test the OEM pressure plate and it would not budge even if I stand on top of it and using two hand with every muscle I have unless I push it and pry with flat screw driver. I even try using the OEM ring on the Fidanza pressure plate and same thing. It came right off.
Anyone have the same or similar issue? I think I just got a faulty pressure plate? I'm so tired after removing everything today. Sigh
