help plzzz
Old Mar 7, 2010 | 09:48 AM
haseeb's Avatar
help plzzz
today somthing very starnge happend to my car ..
i gave 3 to 4 runs to my car on 1.8 bar boost .
the car was running great and strong ,with 11.5 afr ..
on the last run when the road got finished i stoped the car normaly and took a u turn for another pull .
when i presed the accelerater padal the car went full lean and its not getting throttle and missing like hell ,infact its almost impossible to drive the car now ..
now while missing and pushing the accelerator hard when the car reaches 4000 rpm and the boost comes after missing ,the car gets ok and again 11.5 afr on high boost and it runs good like be4 ..
now the car is not stable in low rpm ..
afr full lean ,no throttle response ,missing like hell ..
checked plugs ,pump ,ignition ,cam gear ..
every thing is ok ..
just to tell im running full blown twin pump kit with hob switch and power fc d jetro with aem 3.5 bar map sensor ..
plz help me find wher the problem cud be ...
Old Mar 7, 2010 | 10:23 AM
haseeb's Avatar
Any 1 ?
Old Mar 7, 2010 | 10:52 AM
awd2gen's Avatar
Are you running a maf?
Old Mar 7, 2010 | 10:54 AM
haseeb's Avatar
No ,its 3.5 bar map ...
Old Mar 7, 2010 | 12:13 PM
haseeb's Avatar
no body
Old Mar 7, 2010 | 01:35 PM
zedevo's Avatar
check ur Injectors ... i had the same Prob and it was Inject # 4 ...
good luck ...
Old Mar 7, 2010 | 03:12 PM
haseeb's Avatar
Will do it ,,
