evo flywheel
Old Mar 12, 2010 | 12:02 PM
mrtalon20's Avatar
evo flywheel
Hey was wondering if the Evo and Dsm flywheels are the same the reason I ask is because I need a ring gear just bought a ptt clutch kit.
Old Mar 12, 2010 | 12:06 PM
n2oiroc's Avatar
the flywheels are different.
Old Mar 12, 2010 | 12:13 PM
mrtalon20's Avatar
That sucks cause i need a ring gear lol.
Old Mar 12, 2010 | 08:26 PM
awd2gen's Avatar
hey i have the ptt. You need to use the ring gear off of your stock flywheel. I had machine shop do it. took them about 30 min and cost me $20. They heat up the ring gear to get it off the stock flywheel then it is put in the ptt and its cooled. It is the only way to do it. Make sure who ever you have do it or if you do it that you dont cut the ring gear to remove it and weld it back together. Has to be done the heated and cooled method. I talked to ptt and 2 vendors about it. You cant get a ring gear anywhere. Mitsu doesn't even offer it in the US.
Old Mar 12, 2010 | 10:04 PM
mrtalon20's Avatar
ok thanks man.
Ians06
Mar 6, 2016 04:35 PM
Dvolution
May 30, 2013 11:40 AM
03TarmacEVO
Sep 5, 2012 09:06 AM
4g63Evo8
13
Aug 15, 2012 10:05 PM
FastAzzEvo
51
May 21, 2007 06:44 PM
