4G64 100mm crank safe???
Old Mar 19, 2010 | 02:01 PM
RockmanX's Avatar
pretty sure stock 100mm crank is in my 2.4
Old Jul 24, 2010 | 11:22 AM
RockmanX's Avatar
Originally Posted by doyle4281
I think I just saw a thread from John Bradly with over 1000whp with an OEM 100mm crank
maybe your refering to maps build. and mike has 675whp right now with oem 100mm crank keep up with the times please
Old Jul 24, 2010 | 01:33 PM
JohnBradley's Avatar
Yeah MAP did 1053, I did 794, Mikey did 675 (so far). I am sure there are plenty of other stock crank cars that have made similar power, its just really easy to remember mine, a custome, and the record holder
Old Jul 24, 2010 | 02:13 PM
BLKCarbonEVO's Avatar
There is def more to come. I'm use to the power already!
Mikey
Old Jul 24, 2010 | 05:23 PM
RockmanX's Avatar
have you got that custom hotside yet?? also you get my pm buddy
Old Aug 19, 2011 | 05:52 AM
Carloverx's Avatar
Hey sorry to bump an old thread,
But what prep work should be done to a used oem 100mm crank before going into the build?
I thought I read somewhere turning them in a no-no. Maybe I'm wrong?
Old Aug 19, 2011 | 06:10 AM
okevolutionVIII's Avatar
Knife-edging a 4G64 crank is the no-no as it's already weaker than a 4G63 crank.
Old Aug 19, 2011 | 06:57 AM
Ev0ikon's Avatar
I put about 10K miles on my 2.3L build. It's a new 100mm MItsu crank. Lots of boost. It feels as it the motor is making more power smoothen out the last few thousand miles. I don't know what the WHP number is but Ted.B tuned it. It makes boosted/sprayed V8s play catch up a lot, too!
Old Aug 20, 2011 | 06:30 AM
Carloverx's Avatar
I've got a 2.4 oem crank that i can either:
(a): send out and have it balanced and turned, ($300?) or
(b): replace with a manley forged race series ($550)
Can anyone recommend a shop to work the crank?
Also, if I could definitively confirm the Manley crank is better than oem, I'd rather just order it and be done with it.
ugh.
Old Aug 20, 2011 | 10:15 AM
project_skyline's Avatar
If your crank needs turning probably just better to get another one.
Otherwise balance and polish for prep. I'm personally going with a manley race crank for better oiling and reliability.
Old Aug 20, 2011 | 01:29 PM
Carloverx's Avatar
yeah, that's what i'm thinking. I just don't want to find out 10k miles from now the oem was the better choice for some reason
You would THINK the manley would be better, but for $550, it makes you wonder
Old Aug 23, 2011 | 10:08 AM
Ev0ikon's Avatar
Go with the OEM crank. The only better ones (and ofcourse more $) are Winberg(sp?) or K1 billets.
Old Aug 23, 2011 | 01:01 PM
n2oiroc's Avatar
Based on any facts? I can find plenty of pics of busted oem 4g63/64 cranks. Can you point me im the direction of busted manley or eagle 4g63/64 cranks?
Old Aug 23, 2011 | 01:31 PM
SmurfZilla's Avatar
OEM here. Never had a question about the reliability of the stockers. Thought they were as bullet proof as it got.
Of course my car hasn't started yet so I can't personally quote reliability/longevity
Old Aug 23, 2011 | 04:50 PM
Carloverx's Avatar
I ended up with getting a Manley Forged.
I've heard horror stores of turned cranks spinning bearings. Unless I had a local machine shop i could trust, I just couldn't justify spending nearly as much as a new manley unit, especially since i'm looking more for longevity than shear strength.
Plus, fathouse said he traps 150mph on the manley forged so it'll certainly handle what i'm asking. (between 550 and 600 dynojet whp)
