Oil pressure sender question
Old Mar 21, 2010 | 03:11 PM
AWDPowah's Avatar
So, I got the FP Green installed and found that I needed to pull the oil pressure sender for my oil pressure gauge from the oil filter housing to hook the FP oil feed line up to.
My question is this, where should I hook up the sender to for my oil pressure gauge?
Can I use the oil feed on the head which is now blocked off?
Old Mar 23, 2010 | 04:04 PM
AWDPowah's Avatar
Ttt
Old Mar 23, 2010 | 06:02 PM
fishie36's Avatar
There should be two bungs that are on the oil filter housing which you can tap into. At least there were on my car.
